Question about AOpen Computers & Internet
How do i find my d link router password?
I cant find the password to connect the ipad to my wifi
JerryClinton
    New Friend:
  • 28 Answers
If you are directly connected to the router via ethernet go through the ip gateway, open up a web browser usually d-links ip gateway are 192.168.1.1, you might have to look up you model. Also note you may have a default login and password, such as admin for password and admin for user. note you can also reset the password on the router by holding the reset button for 10 seconds. More questions heres a refrence guide http://www.dlink.com/-/media/Consumer_Products/DSL/DSL%202750B/Manual/DSL_2750B_B1_Manual_v1_00_EN.pdf
Posted on Aug 13, 2014
1 Related Answer
Lynne
  • 102 Answers
SOURCE: I purchased an iPad and
Here are the instructions for a Dlink router initial setup. You will need to get back into your Dlink to change your password. These instructions go into more detail than you may need but they may be good to have.
To configure the D-Link router, you will next need to open a web browser and type http://www.192.168.0.1
You should see the administration screen of the D-link router. type in admin and leave the password filed blank.
A setup wizard should appear, prompting you to first change the router's password. Pick something you can remember.
You will next have to setup a time zone, you will then be given option as to how the router will handle IP address on the network. Most users will opt for the Dynamic option, which means the router will act as a DHCP server and supply all computers on the network with an IP address. If you select DHCP, you will need to Clone the IP address of the machine your ISP has already had contact with. For instance, if your ISP has been giving IP address to a certain computer before you put the router between them, you will need to clone the MAC address of that machine.
If you opted for Static IP Addresses, you will be brought to a screen that you will need to contact the ISP to get IP numbers from.
You will next need to setup the wireless connection. You will change the default SSID to match the workgroup ID of your LAN computers. The SSID and the Workgroup IDs must match. You will also be able to configure encryption at this point. If you have the ability to use the newer WPA encryption, you will want to use this. But we don't recommend setting up encryption until you confirm that all PCs are able to connect properly.
Lastly, you will be asked to reboot the router.
Posted on Nov 24, 2010
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
NBN was connected yesterday but cant figure out how to input the new security code on my iPad. The new mini iPad connected without hassle and so did the PC. The iPad doesn't ask for the security code it...
This may fix your problem... Clear the cache that is stored in the settings.go to general settings ...look for safari ....empty browser history and cache.
then scan for any networks on the wifi settings....when you get to your router....don't enter password or try to connect to it....click right chevron to get to page that says forget network ....then rescan .....this time enter your password....it should connect.....Apple products are not happy if you change or update passwords on routers already configured.
Mar 02, 2015 | Apple iPad 2 Wifi 16GB
My IPAD 2 will not connect to the internet, ir picks up the router but will not communicate
In settings go to reset, network settings.. Make sure your router IP leases rent all assigned, set them for a 24 hour lease time.
reset your router with a 30 second unplug. imthemobile guru
Aug 07, 2014 | Apple iPad 2 Wifi 16GB
Why cant i find my password for wifi connection on my ipad?
If you check your own wifi password than go to wifi setting and click Show characters check box but if you are using router and forgot your wifi router than try to reset your router wifi password. If you need any technical guidance than follow Mac Technical Support .
Jul 06, 2014 | Apple iPhone Smartphone
Authentication problem on android ipad
You will get an 'authentication' problem trying to connect to this dlink 600 or any other wifi services/routers that are 'protected' and encrypted using WEP or WPA or WPA2 security (e.g. not public or 'OPEN' network): apart from the SSID, you will need to set your android tablet or ipad to use the WEP or WPA or WPA2 PASSWORD/PASS KEY to successfully connect (you get it from the Wifi/Router administrator).
Apr 06, 2014 | D-Link DIR-600 Router
Windows 8 will not connect
windows 8 is bit tricky try deleting all existing wireless profiles and refresh the router search option now it should connect or reset the router to factory defaults and put a new wifi password or try without wifi password by removing the wifi security.
Feb 25, 2014 | D-Link AirPlus Xtreme G DI-624 Wireless...
I need a password to reach the interneton my ipad...it asks for a cisco password
If your wireless router was setup using the default configuration, the password, also called a security key should be on the bottom of the router. Alternatively you should be able to specify on your ipad that you want to connect using WPS, and your router will have a WPS button on it. Pushing it for 2-3 seconds would allow your ipad to connect without needing the password. You should be able to google "connecting ipad to wifi using WPS" and if necessary include your router model to get specifics about the location of the WPS button on your router.
Jan 16, 2014 | Computers & Internet
My iPad won't connect to Airport Extreme WiFi
Is your A P E a hidden network?, if so just type in the name of your router name and scan, it will find and ask for a password
Apr 28, 2012 | Apple AirPort Extreme Router
I want to use my Ipad with my d-link wifi system, but I do not know the password to unlock the system. How can I retrieve this password.
If you have not changed the default login to the router then the login is admin and the password field is blank.
However, if you have changed the default login and do not remember it you will need to press the reset button on the back to restore the router to it's factory default settings then you can use the login above.
Hope this helps!
May 03, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Michael Thomas
Michael Thomas
Joe Goldman
Joe Goldman
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
