Question about Mitsubishi WS-65807 65" Rear Projection Television
Tv 65 mitsubisi no sound no picture
Turn on tv no sound or picture
Mitsubisi tv makes clicking sound to come on and then goes right back off
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now.
Sep 13, 2012 | Proscan PS27500 27" TV
As I was watching tv, today, I heard a "pop" and the picture blackened on the tv. I have a mitsubisi 65 inch dlp. There is no picture, only sound.
There might be a shorted capacitor in the video amplifier section. You can locate it through the physical appearance of the capacitor it is blown up. Replace it with same value but you have to get first the voltage output across the capacitor it must be within the voltage capacity of the capacitor. If the voltage output is higher, there is problem with the voltage regulator in the power supply section.
Nov 17, 2010 | Televison & Video
Need tv code for mitsubisi 1080P
Codes for URC 3021 to programme mitsubisi TV are
0093, 0150, 1250, 0178, 0836
thanx
Aug 01, 2010 | One For All URC-3021 Remote Control
Set worked fine when turned off. Now nothing happens when pwr button is pressed. Timer light does not come on. If system reset button is pressed, pwr led flashes for 60 secs. System is still dead. Status...
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.If you hear strange noises like buzzing or humming noises it could be the color wheel which is a little disc that has a gamma of colors and spins at high rpms.When the light of the lamp goes through it creates the colors on your tv.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on. For parts you can find them in partstore.com shopjimmy.com or discount-merchant.com God bless.
Feb 09, 2010 | Mitsubishi WD-65732 65" Projection HDTV
There was a slight squealing and then a loud pop and now no picture. We have sound but no picture. Toshiba 65" rear projection set.
Sound like the color wheel exploded. When this happens the tv will not let it turn on, now for the real bad news,,,, Toshiba does not supply just the color wheel, you will have to replace the entire light engine for around $450.00 to $650.00
Dec 18, 2009 | Toshiba 65HM167 65" Projection Television
65" projection tv will turn on and shut off before picture comes
the service light is blinking because you in fact need a new bulb also is why u have no picture
Oct 06, 2009 | Sony KP-53V75 53" Rear Projection...
I have a Mitsubisi rear projection TV the picture goes in and out in and out and goes out of focus when that occurs. Sometimes the TV will just turn off by itself because of the in and out. Has anyone ever...
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
