Question about Lexmark X1270 All-In-One InkJet Printer
Searching for scanning applications error?
Download compleats and at the end message says "searching for scanning applications" and continues to search forever. first use of software.
Linda Deatherage
    New Friend:
Are you wanting to scan? Click on the help toolbar and type in what you are looking for.
Posted on Aug 12, 2014
2 Related Answers
Anonymous
SOURCE: Lexmark All in One - Forever searching for scanning applications!
I had the same problem with my Lexmark x1150. After a few hours of searching on the internet I found the solution at this forum http://www.techsupportforum.com/hardware-support/printer-support/64233-lexmark-p3150-3100-a.html
Lexmark made a fix for this Goto the FTP server of lexmark and download the Searching for scanning applications fix for your printer @ ftp://ftp.lexmark.com/driver/
For instance I have the Lexmark All in One center 1100 Series so my patch is located @ ftp://ftp.lexmark.com/driver/inkjet_drivers/1100%20Series/AppSearch/
favicon.icofavicon.icowiki-favicon-sharpened.pngoneriot-favicon.ico
Posted on Sep 06, 2009
SOURCE: Preparing for Scanning Application box
dear uninstall your printer driver .......
shut down your system and disconnect printer .....
open system and install driver ......
after installation connect printer
and enjoy it ..................
Posted on Nov 17, 2009
Testimonial: "I would say the response was fast but that would be an understatment. Wow! Are you guys good, or what? Thanks a million!"
How to install game software
To download and install applications onto your Sony Ericsson Xperia X10, follow these instructions:
  1. From the Home screen, tap the applications bar.
  2. Tap Market
  3. When you open Android Market the first time, the Terms of Service window will appear. Tap Accept to continue.
  4. To search for an application, tap the Search icon, enter the search string and then tap the Search icon again.
  5. To install an application, tap the desired application and then tap Install.
  6. The applications wlll download onto your phone and automatically install.
  7. You'll then be given the option to open up the application on the Sony Ericsson Xperia X10, or close the window.
Mar 26, 2012 | Sony Ericsson XPERIA X10 Cell Phone
I cannot get my cannon to scan a photograph from printer to computer - please help before I push it off desk.... thanks
First - verify that you have installed the printers software on your computer before connecting it to your pc? If you have not installed the printers software, or do not have the disk to do so - go to Cannons website and download it to your pc. www.cannon.com. Click on support, then find download drivers/software and enter your make and model of your printer. Follow the prompts to download and then install it.
How do you know if you have or do not have the software already installed? You should be able to find the cannon software for your printer on your desktop. look for the icon.
Once you have the software installed, there are two ways to scan something to your computer.
You can scan from the printer to the pc. Or you can scan from the pc to the printer. What does that mean? It means you can use the printers keypad and send the image to the pc. Or you can open the software in the computer and request the image from the printer. You either send or request but the end result is the same.
The easiest way is to use the software in the computer. Double click on the cannon software on your desktop. Find the "scan" option and click on it. Make sure your printer is turned on and connect and click "ok" to start the scan. The picture will appear on your screen. You can adjust it when its finished.
If you want to try and scan using the keyboard on the printer. press the scan button. The printers display will say "searching for applications" and there will be a delay until it is finished. The printer is searching for compatible applications to send the image to. The choices are usually microsoft word, Adobe pdf, internet explorer followed by any graphic or image software you have installed that the printer recognizes and the cannons default software. When its done downloading the applications, you have the ability to choose which one you want to send your image to. Press the "send to and pick the application you want to use" on the printers display. Then press "enter" or "ok" and the image will be sent to that program and appear on your computer screen.
Mar 08, 2011 | Canon PIXMA MP470 All-in-One Printer
Searching for Scanning Applications error message
Have you plugged the printer into the PC? Sorry to have to ask this but it is amazing how many people don't realise that this is required (USB lead usually). I don't know how old the printer is but your problem may be because the printer software is not compatible with the new computer (I.e. software for XP and you have Vista, or something like that).
Dec 01, 2009 | Lexmark X1270 All-In-One InkJet Printer
How do you take a scanned article and transfor it to adobe reader 9 to alter document? I need to change the format i guess so it would register the material.
If you are working with a scanned document (TIFF, GIFF, etc) you must use an Optical Character Recognition (OCR) application to translate the scanned text into editable text. An application such as Omnipage will do this.
If you want a less expensive/less feature rich application try some of the trial OCR applications on ZDNET downloads at
http://downloads.zdnet.com/search.aspx?q=ocr
Nov 10, 2009 | HP Computers & Internet
MYWEB plug in error message
Uninstall the My Web Search option from Add/Remove Programs
1) Click on Start, Settings, Control Panel
2) Double click on Add/Remove Programs
3) Find "My Web Search" in the list of installed programs and click on Change/Remove to uninstall it. You may also want to uninstall any of the following items associated with FunWebProducts.
My Web Search (Smiley Central or FWP product as applicable)
My Way Speedbar (Smiley Central or other FWP as applicable)
My Way Speedbar (AOL and Yahoo Messengers) (beta users only)
My Way Speedbar (Outlook, Outlook Express, and IncrediMail)
Search Assistant - My Way
Aug 04, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Jun 24, 2009 | Lexmark P3150 All-In-One InkJet Printer
I cannot download or open any msi file type.
It just, no application can open that file so windows is suggesting to search for application to open/run that kind of files. Say example you have pdf file and you don't have adobe reader or application that can open pdf format it will flag that kind of message for you to be able to view/run it.
Hope it helps.
Apr 24, 2009 | Dell Inspiron 1720 Notebook
Lexmark x5250 printer software still not working.
Ok,
I think I have it.
Go to Lexmark Support.
In the "Search by Model" box enter x5250. When the model pops up, click it.
In the "Search the KnowledgeBase" box enter "searching for scanning applications". Click "Search".
You will get 2 choices. Click the bottom one, "How to Add a Scanning Application to the All-In-One Center".
Follow the instructions given.
Comment back.
Nov 03, 2008 | Lexmark X5250 All-In-One InkJet Printer
Can't scan on HP Photosmart C4380 even tho printing works fine
Try scanning without HP imaging software
HP Photosmart C4380 Direct Scan button doesnt function in VISTA
Use the built-in feature of the Windows operating system, called Windows Image Acquisition (WIA), instead of the HP software to scan. Follow these steps to perform a WIA scan.
  1. Make sure that the product is on and that the cable is correctly connected.
  2. Click Start , and then click Control Panel .
  3. Click Printers and Other hardware , and then click Scanners and Cameras .
  4. Look for an icon representing the product, and then review the following information for further instructions:
  5. Double-click the icon to start the Scanner and Camera Wizard . Follow the on-screen instructions to scan images or documents to the computer
  6. If the WIA scan was successful , use the Scanner and Camera Wizard to scan instead of the HP software. To use the HP software, continue to the next step to continue troubleshooting. However, it is not necessary to do so.
  7. If the WIA scan was unsuccessful , continue to the next solution.
  8. Fully uninstall and reinstall the HP software Follow these steps to completely uninstall and then reinstall the HP software. Step one: Uninstall the software Use one of the following methods to uninstall the software. Method one: Uninstall the software using the product CD If the product software CD is available, follow these steps to uninstall the software. Otherwise, skip to the next method.
    1. Insert the software CD into the CD-ROM drive on the computer.
    2. If the Welcome installation screen appears, click Exit to close it.
    3. On the Windows task bar, click Start , and then click Run (c01463550.gif ). The Run dialog box appears. Figure 4: The Run dialog box c01463551.gif
    4. Click Browse . The Browse window appears.
    5. Navigate to the CD-ROM drive that the software CD is in, and then double-click the drive.
    6. From the list of folders and files on the CD, double-click the Util folder.
    7. From the list of folders and files inside the Util folder, double-click the CCC folder.
    8. From the list of folders and files inside the CCC folder, double-click the Uninstall_L3.bat file or Uninstall_L3_64.bat if a 64-bit operating system is installed on the computer. The Browse dialog box closes, and the path to the Uninstall _L3.bat file appears in the Run dialog box. Figure 5: Uninstall file path in the Run dialog box c01463552.gif
    9. Click OK . The software uninstaller opens in a command prompt window.
    10. Press Enter to begin the uninstall.
    Method two: Download and uninstall the software If the software CD is not available, follow these steps to download the software and then uninstall it.
    1. Click here to go to the Software & Driver download page on the HP Web site .
    2. Type the product number in the search field, and then click Submit (c01425574.gif ).
    3. If necessary, click the link for the product model number.
    4. Click the correct operating system.
    5. In the Driver section, click HP Full Feature software/driver , and then click Download only .
    6. When the File Download - Security Warning dialog box appears, click Save .
    7. Save the file in a location that is easy to remember.
    8. When the file finishes downloading, double-click the file to extract it.
    9. Click Exit on the Welcome installation screen.
    10. On the Windows task bar, click Start , and then click Search (c01463553.gif ). The Search Results window appears.
    11. In the Search Results window, click All files and folders .
    12. Click More advanced options , and then select Search hidden files and folders .
    13. In the All or part of the file name: box, type Uninstall_L3 , and then click Search . When the search is complete, the file appears in the Search Results window.
    14. Double-click the Uninstall_L3 file, and then follow the on-screen instructions to complete the uninstall.
Oct 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
Wont sacn
Hi Danger, I think the compleate message when you try to scan from the scan button is NO scan options install or load software... if yes this can be solved by performing the solution below: You can try to scan from the HP software Clik on start>> All programes>> HP >> HP director and then try to scan from it. If the scan from the HP software works try the steps in the below weblink this will fix the issue.. http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00503569&cc=us&lc=en&dlc=en&dlc=en&lang=en You can also try to download and run the HP scan diagonistic utility: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-45265-1&cc=us&lc=en&dlc=en&product=390315&dlc=en&lang=en Just click on the above link and in the download webpage click on the download only button and select save to save the software to the computer desktop and run it to check with the scanning issue and once the utility is compleated click on the fix button so that it will try to fix the issue. If the issue still presists try to uninstall and reinstall the HP software. Wish you success Regards, Barret.
Sep 17, 2007 | HP PSC 1610v All-in-One Printer
Lexmark X1270 All-In-One InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
