Question about JVC LT-42X579 42 in. LCD TV
Access service menu on jvc LT-42P300
Service menu
eLX Elcideed
    New Friend:
  • 3 Answers
Here is the source to get the service mode code
JVC http://tvservicemenu.blogspot.com/search/label/JVC
Posted on Jan 02, 2015
    Top Expert:
  • JVC Master
  • 76,416 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Aug 12, 2014
4 Related Answers
Jim Krause
  • 1779 Answers
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Posted on Feb 04, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: How do I use timer on JVC LT-42P300
For turned OFF enter in the set menu select the sleeper time(15-30...minutes).
For set the turn ON if you do not have the good signal it is imposibile.
Posted on Sep 02, 2009
Anonymous
  • 8 Answers
SOURCE: JVC LT-42P300 Remote Codes
try other codes for different tv's. or try the search mode on your remote control. you may need a newer remote that is compatible with your tv
Posted on Sep 19, 2009
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: I have a LT32X576 JVC.
Firstly, you need to be in "TV mode" to make adjustments in the audio/sound menu. If you are using a cable or satellite receiver connected by HDMI, Composite, Component or S-Video cables, the TV will be in an external input mode and the audio menu on the TV will not be accessible.
Try pressing the INPUT button on your JVC remote repeatedly until you are back in TV mode. Then open the menu again and see if the audio settings are accessible. (Watching TV channels from a cable or satellite receiver using INPUT 1, 2, 3 or 4 does not mean you are in TV mode).
Secondly, if you are using a cable or satellite receiver, it is quite common for the TV to appear to lose audio because the receiver has "crashed" and has stopped sending audio to the TV. This can be resolved by re-setting (re-booting) the cable/satellite receiver. Some have a reset button on the front or back, some need to be switched off and on again, and others need to be disconnected from the power supply for a minute or so.
You really need to establish why there is no audio. It is a good idea to test the TV with another external source, e.g. DVD player, VCR or game system if you have one. If you have audio on the TV from one of these devices, there is no problem with the TV. If you are using a cable or satellite receiver, these are likely to be the cause of the problem.
If there is an audio failure with the TV, it is likely to be either something simple as detailed above, or a hardware fault with the TV, which may require professional repair.
Please try the simple tests above and let me know the results if you need further assistance. Please reply to be by clicking on "Add a Comment" below your question.
Thanks,
BElectric
Posted on Mar 02, 2011
Service menu
Service mode entry method to this set is too much to type in here, and is not practical. For more information go to http://electronicshelponline.blogspot.com/
Dec 01, 2013 | JVC LT-32P679 32 in. LCD TV
How to open wap connection
Internet access setting for Motorola RAZR V3X : 1. Go to menu => Web Access => Web Sessions => new entry
2. Fill in a account name
3. Select Access Point settings
4. Set service type to WAP
5. Enter GPRS access point (APN) 6. Enter User name and Password
7. Select myGlobe GPRS.
8. Press menu
9. Select set default
Note : you have get valid names /codes form service provider of number 2,5,6. Different operator will has different setting.
Dec 04, 2010 | Motorola Mobility RAZR V3x Cellular Phone
What remote? It depends on the remote. Different remotes use different codes. They all have a code search function that you can use to find the code.
Sep 19, 2009 | JVC LT-42X579 42 in. LCD TV
Sep 02, 2009 | JVC LT-42X688 42 in. LCD HDTV
Service Menu
You have to press >*<<*<* to access the service menu ...
Jun 20, 2009 | Sony Ericsson K550i Cellular Phone
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Jan 02, 2009 | JVC LT-42X688 42 in. LCD HDTV
How do you get the DR-MV1 into service mode?
service menu? do u mean the menu? if u have it's remote...it should be in "menu".
Mar 29, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC LT-42X579 42 in. LCD TV Logo
752 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
