NorStar T7208 Corded Phone Logo
h
hi tech autos Posted on Aug 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2 lines dont work - NorStar T7208 Corded Phone
Jerry Kramer
Level 3:
  • NorStar Master 3,933 Answers
  • Posted on Aug 12, 2014
Jerry Kramer
NorStar Master
Level 3:
Answers
3933
Questions
Helped
882228
Points
12076
You have to have two lines coming into the phone to have separate lines. Call the phone company.
Every time I print or receive a fax, it kicks me off of the internet.? PLEASE HELP!! Thank you :)
Try it:1..Telephone line straight away to system modem line in socket.. from modem line out socket to printer line in socket(marked as box symbol)dont insert tele phone line in phone symbol socket.. 2..Telephone line straight away to printer line in socket.. from extension socket(marked as phone symbol) to system modem line in socket...Note:dont split telephone line like branch.. Describe this issue with telephone operator because of both fax & internet will work in digital signals, result conflict may happen..
Printer kicks me off internet
Need to replace the brake lines in the rear. I have 3 1/4 lines. Will these work?
if u r replacing the steel lines on the rear axle then no....those lines r 3/16 lines..but if ur replacing the steel line from the front to the back of the car then yes they will work but dont forget to get line unions to connect the lines together
At work we have a panasonic kx-t7668 telephone. I have followed the instructions on (one-touch dialing), but now when we have incoming calls in the office i dont have a red light that flashes at me, so i...
Did you do something stupid like program over the top of the buttons? Press PROGRAM and, starting from the bottom press a button, then dial 0 01 STORE Move up the line and press 0 02 STORE etc. Do that for however many lines you have and it puts the lines back into the Single-CO sequence that you probably started with. (PROGRAM is done from an idle phone and you press PROGRAM to exit).
Carl
1helpful
L1 r1 dont work on my dsi
if still in warrenty take back to shop otherwise open the back of the dsi and check the buttons are lined up correctly
2helpful
2answers
Cruise control dont work! light comes on but doesnt work is this in the wiring?
check the vacuum lines. most likley a broke or cracked vacuum line (under hood)
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
3helpful
2answers
TIMING BELT MARKS DONT MATCH AFTER ENGINE TURNED OVER
dont worry about that you will have to turn the motor over 40 to 50 time before those timing belt marks line up again if your pulley marks line up correctly thats all you have to worry about
1996 ford windstar gl
for rear defroster grid lines, there are tiny gaps or cuts in the grid lines. get repair kit and paint over gaps. use masking tape so lines aren't too thick. kit @ $10. you can do this.
Heater dont work, only cold air dont hot
It could be one of three things. The heater core, water pump, or a air pocket in your lines
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
