Question about Humminbird 597 Ci Hd Combo Sonar/Gps
Why does my fish finder sieze up when i start my boat?
Posted by peter johnson on
Josh Van Nostrand
    New Friend:
  • 62 Answers
It seizes up because their is a very hi draw on your battery when the motor is turning over, the starter draws so much power from the battery that it drops the voltage down below what the depth finder needs
Posted on Sep 05, 2014
Our 797 Hummingbird fish finder will not turn on any ideas why
Battery too low
Fuse blown
Corroded connections at battery, fuse, connector
Dead fish finder
Jul 09, 2017 | Hummingbird Boating
I have a eagle fish finder, it is a vg-250. i need a manual for this fish finder.
Hey Floyd, check this out:
www.eaglenav.com › Downloads
May 31, 2017 | Eagle Boating
Lowrance 112c gps shuts off when cranking main engine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} This is very common when using a single battery system in you boat.
If you more then battery connect the fish finder to the second battery.
Or if the Depth finder is connected through the acc. on the boat. The power is being cut off be fore the starter is engaged. By pass this and connect through a correct size fuse.
May 08, 2009 | Lowrance Lcx 112c 10.4" Gps Fish Finder...
I need a humming bird fish finder 4000 Manaul
http://www.humminbird.com/PDF/lcr4000.pdf
I hope this is the one you are looking for.
Mar 23, 2009 | Boating
Need a op. manual for uniden mc-600 fish finder
There is not a Uniden Marine Electronic with MC-600. Here's are all the manuals for Uniden Marine Electronics =>
http://www.uniden.com/index/manuals_results.cfm?cat=7
If it's the Cobra Fish Finder MC600, here's the operation manual =>
http://www.cobra.com/downloads/manuals/MC600C_MANL_ENG1.pdf
Jan 03, 2009 | Boating
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Humminbird 597 Ci Hd Combo Sonar/Gps Logo
101 people viewed this question
Top Humminbird GPS Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Andrew Taylor
Andrew Taylor
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
