Question about Kyocera Mita Office Equipment & Supplies
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Joseph Koata
    New Friend:
  • 12 Answers
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Posted on Aug 28, 2014
2 Related Answers
SOURCE: Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Posted on Aug 15, 2008
fixxy
SOURCE: Have Kyocero 2050. Error - Misfeed paper - Open
I was having the same problem with the same model and same error. Then I discovered there's an extra panel you can pull out of the side - it's not the one the display is indicating, it's the one all the way on the side. When you pull on the grey level and it comes down, keep pul;ling on the grey level because ANOTHER panel comes down under that and I found some paper jammed in there. Once I removed it it worked fine.
Posted on Feb 19, 2013
Troubleshooting
the error is for the drum not being set in place remove the process unit and open the left side cover where the drum is located. Remove the toner waste bottle and make sure the drum is pushed in all the way if it is you may need to replace the drum.
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
4helpful
2answers
Have Kyocero 2050. Error - Misfeed paper - Open Left Cover and remove misfed sheet. Jam 00. I opened left-side cover and found no sheets stuck anywhere in sight. I can't find Jam 00 definition in...
2helpful
My kyocera printer km 1820 won't use paper on the loaded auto tray. It you press paper select - then auto - it asks for paper to be loaded on the MP tray. The local technician told me to press...
cheap kyocera mita copier repair and parts installation just txt or call 09194851549, 09168932315 also offering free estimate within metro manila (ncr) philippines any kyocera mita brand we can fix it!!!
2helpful
Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
2helpful
Kyocera km-f650 keeps saying self testing...
Open the top cover and remove the toner cartridge.
Unplug the power cord
hold down the ENERGY SAVER KEY while plugging back in
display should say RAM INITIALIZE
scroll down to SHIPMENT SET
press SET
press 2
Wait for the machine to reinitialize.
4helpful
Hopes this helps.
Henry
1helpful
2answers
Black smudges on copies
Hi, try to pull out complete process unit(cartridge) with toner box .You have cleaner(blue or green color) move this cleaner from right to left side 4 or 5 times.Note that cleaner MUST be in home position-right side when you finish.Check print.
If problem still persists, you must do following:take away small grey plastic cap on left side of cartridge,then push complete charge corona(part with cleaner on top of it) to left side just enough to lift right side of corona from cartridge.Pull out that corona and you can see drum and developer roller. Turn the gear on drum,and look for smudges on black developer roller.Try to clean smudges with brush or with dry cloth.Toner will again attract to that area,but regular.
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
Ekse
Harrie
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
