I have a 2001 Sport Trac that the door handle will not open the door from the inside ...... I have to roll down the window and open it from the outside. I would like to fix it myself, is there a site where I can view any drawings to see what I'm dealing with to fix the problem and is this a normal wear and tear common? Thanks.
Most likely a $2 plastic clip broke or fell off the actuating rod. No site that I know of, but the library should have a service manual for your vehicle. In any case, you will have to remove the inner door panel and/or the exterior handle. Check for screws on the outside handle. If ya get lucky, you can remove the handle from the outside and fix it there. If not, remove the door panel and replace the clip and rod from the inside.
