Says 80/81
SOURCE: WINE COOLER WILL NOT COOL,TOP EVAP FAN NOT RUNNING
click on the link below and you will find parts for your unit
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=DWC512BL&productCategoryId=0169000&brandId=3055&modelName=WINE-COOLER&diagramPageId=00001&documentId=50031941&pop=flush
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
SOURCE: Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
SOURCE: The Danby wine cooler Model
Sounds like the unit may have lost the refrigeration charge and or there is a problem with the compressor. Check your warranty depending how long you have own the unit it may be covered.
A manual can be downloaded from the following site.
http://www.retrevo.com/support/Danby-DWC283-Refrigerators-manual/id/886ag725/t/2/
Jim...if this information helped you please leave a comment...Thanks!
SOURCE: code E4 on dandy wine
We had that problem in 2007, about 10 months after buying it from Costco. It was under warranty so the tech came and changed both sensors. It's worked fine until Feb 11. Now, the lower section ran so cold it froze some bottles. I am looking for a solution to that problem.
