Just installed and it tells me Roxio has quit working
SOURCE: The Certificate File is missing or Corrupted.
U have error in or installation or ur software hsd missing their some file.First u wninstalled ur previous version then installed newly
SOURCE: When installing Roxio Easy CD & DVD Burning in
Roxio always had compatibility issues with Vista. I think its better not to use. It also gives some Drive errors like stop showing the CD/DVD drive.
If you have any problems, go to their forum.
Its better to use this.
If this helps you to solve ur problem, please kindly rate the answer :)
Good Luck.
SOURCE: I can't install a program with my cd dvd rom after
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
SOURCE: Set Up Error Report:AppName:setup.exe
1. Open Windows Explorer.
2. Follow this path C:\\ Program Files \\ Common Files \\ Install Shield locate the sub
folders Engine and IScript.
3. Rename (Right Click and choose "Rename" both folders example: Engineold &
IScriptold.
4. Close out of Windows Explorer and run setup again.
5. Apply the latest update patches from our website www.roxio.com.
www.roxio.com
Mel
Testimonial: "Followed instructions exactly, it did not work. Regards, Saurabh Jani. "
SOURCE: Roxio burn exe file problem
I can't find the Roxio Burn on my computer. I keep using the shortcut on desktop, but it keeps popping up that the shortcut isn't useful if not installed. But it came installed on my computer when I bot the computer a month ago, and I have actually used it to burn a couple of cd's, but I can't locate it now. What is the problem?
