Replace interior lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Posted on Jan 25, 2015
Good Evening Gary, thank you for your post!
From the information you have provided you need to replace the lightbulb inside of your Frigidaire microwave. I have researched your microwave and you are unable to disassemble your microwave in order to replace the lightbulb. In order to provide you with a proper resolution I would suggest seeking assistance from a professional technician for repairs. This will help you avoid unnecessary part purchases or personal injury. -Matt
Jun 13, 2015 | Frigidaire Microwave Ovens
Feb 16, 2014 | GE Microwave Ovens
Feb 16, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Mar 30, 2012 | GE JVM1440 Microwave Oven
Apr 09, 2010 | GE Advantium 120 Convection/Microwave Oven
Dec 13, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Nov 24, 2009 | Maytag Appliances Over-the-Range Microwave...
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Mar 26, 2008 | Microwave Ovens
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
233 people viewed this question
