Ekornes Stressless Paradise Sectional Logo
A
Anonymous Posted on Aug 10, 2014
How do you change the sectional from right facing to left
I know it can be done because they did it before I bought it off the floor.
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244943
Points
21965
How to choose left or right facing sectional?
This means that as you are facing the sofa, the arm is on the side mentioned. Right-Hand Facing: If you are standing facing a sectional and the chaise is on the right, it is a right-hand facing chaise. The arm of chaise is on the right, because the sofa continues to the left. http://www.modgsi.com/Sectional-sofa-Left-hand-Facing-vs-Right-hand-Facing_b_1.html
  • bulekini
    bulekini Mar 19, 2019
    I just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
    Visit sitehttp://Theprocoin.com
I have 2010 jeep compass,i get heat only from left ports center and right blow air but its cold.will change from floor to face to defrost but only hot on left side
dampers struck.
scan it yet, most the newer jeeps , you can scan it or run self test
to get the errors and clues as to why.
the SM cover that, read the factory service manual
or get car serviced.
1helpful
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Preliminary Procedure
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
Preliminary Procedures
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Front Floor Console Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Front Floor Console Assembly
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
Pulled hamstring
my doctor had me lay on a cushion with my body positioned halfway through a doorway..raise my leg(s) one at a time and rest my heel(s) on the door facing trim with the bottom of my foot facing the cieling..this extends the hamstring..all this was done on my back..I had a ruptured disc in my back and both hamstrings were too tight..had to stretch them..when in this position the leg runs right up the door facing..heel hooks onto the trim..do this for about 10 minutes a day..works best on a carpeted floor..put a pillow under your head..you can also do rotary stretches by lay ing on your back on the floor raise the leg straight up and rotate at the hip..let the foot come about 6 inches off the floor (right foot to the left side.. left foot to the right side).. this helps with flexability.. do it slow and methodical..
2answers
1990 dodge dynasty. car had no brake pedal,replaced master cylinder ,got good pedal, and solid stream from all but the left rear,changed the proportioning valve,now have good stream and solid pedal,until...
There must be a leak or air in the system, try bleeding the system with the car running, have some one pump pedal threee times and hold while you bleed, tell them when to pump and hold. start at right rear wheel then move to left rear then right front and last left front, when done check lines and connections for leaks, make sure to bleed system good, let me know what happens and also does this car have abs system
6helpful
Can't get the door back on
Instructions
Open the door to the dryer and remove the screws in the hinge. Lay a towel on top of the dryer. Place the dryer door on the towel with the inside facing up.
Remove the screws from the inside of the dryer door. Disassemble the dryer door carefully, removing the cover on the right side of the innermost section of the door and the shield and hinge from the left side of the innermost section. Reattach the side cover to the left side of the innermost part of the door. Install the new shield to the right side of the door section, with the flat side against the door and the notches facing up (they will face into the dryer). Attach the hinge on the same side as the shield.
Set the top section aside. Rotate the remainder of the door 180 degrees so that the handle is on the left of the upside down door. Check that the latch aligns with the cover before screwing the door back together. Screw the hinge into the corresponding holes on the left side of the dryer door frame. Remove any stickers that might be blocking the holes.
Check the alignment of the door by opening and closing it several times. Loosen the screws on the hinge and nudge the door slightly until the fit is correct. Tighten the screws into place.
Jan 09, 2013 • Dryers
Change from 480 3 phase to 220 single phase
The way Miller made that one, if you do not have the unit that is made for 200/230/460, you cannot make that change.
The manual section 5 page 12 has the exact procedure, but in a nutshell, (assuming lockout procedures are done) remove the red power lead and tape off/insulate it. L1 and L2- the black and white power input leads are attached to the single phase power, AFTER the ground wire is connected to the ground of the disconnect. The fuse should be a 90 amp regular or a 70 amp time delay. The relinking board should be checked to see if it is on 460 or 200/230. The manual is not entirely clear on this in section 5 page 10, but the relinking should be on the 200/230 connection. It will be located in the lower portion on the right side as you face the front of the machine. On the right side of machine with lower panel removed, if will be just left of center up near the top of that lower opening. . it is held in place with 4 screws- and once moved to the correct position, all 4 screws must be used to secure the board in place.
The manual is availabe at the miller welding website as well.
http://www.millerwelds.com/service/ownersmanuals.php?model
1helpful
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
1helpful
2002 vue early production 4 cyl. Heating/AC vents - no output
Hi there, Sounds like a vent door switch. It's in your dash and it controls the vent door opening and closing and to which duct the air goes to, defrost, face vents, floor. Best thing to do is buy a Haynes or Clinton's repair shop manual at your local AP store for your particular vehicle. Then read up on it in the trouble shooting section or the step by step RR section. You can purchase these at your local Auto Parts store or buy them on line at ebay burdfrenzy
Thanks....and another question blueextc3221 was so right when I opened 2nd floor 3 way switch,there were burn marks on the face plate and an unsecured wire. It's hard to tell which,if any, is a ground wire...
Go to google, knols is under the 'more' section. I have a knol called 'Electrical Troubleshooting for Dummies'. There's a section in there on 3-way switches that will help you.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Top Ekornes Wine & Spirits Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Don A
Don A
Are you an Ekornes Wine and Spirit Expert? Answer questions, earn points and help others
