Question about Canon PowerShot A520 Digital Camera
I have tried reseting the date and time on my camera and it won't do it
You might need to replace the cmos battery to correct the problem .
Posted on Aug 22, 2014
SOURCE: WHERE CAN I GET A FREE USER GUIDE FOR A canon powershot a520
http://www.starbatteries.com/capoa5dicaow.html#Instructions:
Heres a link for you.
Posted on Jan 09, 2009
SOURCE: Powershot A700 camera won't save the date and time
The date battery needs to be replaced. It is a CR1220 "button" battery. Instructions for replacing it are on page 117 of the Advanced Camera User Guide, which can be viewed/downloaded here.
Posted on Feb 23, 2009
SOURCE: everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
Posted on Sep 12, 2009
SOURCE: time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
Posted on May 25, 2010
SOURCE: every time I set the date/time on my camera and
Replace the date/time battery on the side of the camera.
Posted on Jul 15, 2010
