Question about Dell Axim X5 Pocket PC
SOURCE: Dell Axim X5 Screen Back Light Trouble
Holding down the record button on these units turns the backlight on and off, since this is hardware controlled you should try this first. If you've performed a hard reset and held down record then this is most likely a physical fault, check with Dell to find out your warranty status and find out about the availability of replacement parts.
Posted on Aug 29, 2007
SOURCE: Axim X5 Align Screen Loop
I am by no means an expert but I have had the same problem that you are having and I found that after I took my X5 apart and cleaned around the underside edge of the plastic housing frame that was at the edge of the screen the problem went away. I also cleaned the front of the screen very well and put a new back-up battery in. I have not had the problem since.
Posted on Oct 22, 2007
SOURCE: Align screen loop?
Look at this http://www.fixya.com/support/t132057-getting_past_align_screen
you basically need to get the wire to stop touching the home key, which can be accomplished (as described in the link) with either the quick fix method, wedging something in the bottom screen, or the better-long term method of opening the axim up and taping the part that has shorted.
best,
Greg
Posted on Jun 14, 2008
SOURCE: Can I use Standard 4G or 8G SD or Cf cards in a Dell Axim X5?
SD cards must be SD not SDHC, there is not an SDHC driver for the X5. You can find regular SD cards up to 4G.
CF is no problem, all flash based CF cards will work. Microdrives can be problematic.
Posted on Feb 24, 2009
SOURCE: Axim x5 sd not reading
I have a 2 gig Lexar micro sd card that works fine in my Axim x5 with a couple of SD adapters I have. However, my Dane-elec 4 gig micro sd HC won't...Not sure what the deal is but I'm told it's the HC part that causes the trouble.
Thank goodnes it has two memory card slots!
Posted on Apr 30, 2009
Jun 21, 2010 | Dell Axim X5 Pocket PC
Jan 03, 2010 | Dell Axim X5 Pocket PC
Jul 02, 2009 | Dell Axim X5 Pocket PC
Apr 18, 2009 | Dell Axim X5 Pocket PC
Jul 24, 2008 | Dell Axim X5 Pocket PC
Dec 02, 2007 | Dell Axim X5 Pocket PC
Nov 02, 2007 | Dell Axim X5 Pocket PC
Sep 05, 2007 | Dell Axim X5 Pocket PC
Sep 14, 2005 | Dell Axim X5 Pocket PC
Feb 15, 2011 | Dell Axim X5 Pocket PC
