Question about MTX Car Audio & Video
Why blades won't engage on my mtd 54" rider?
The mower starts and moves good but blades won't engage
Posted by eddie bubba on
Tim Hofstetter
    Genius:
  • 1,406 Answers
Broken or loose PTO belt, or PTO shifter linkage.
Posted on Aug 10, 2014
Why won't the blades engage on my riding mower 54" mtd 13ap625k730?
You have probably thrown the belt for the blades. If it continues to throw the bet check the tensioner.
Aug 10, 2014 | Mtd Garden
When engaging blades engine dies after mowing over 2in sawn off tree stump
take deck belt of and check that blades stiil turn by hand most likley bent or broken
Feb 23, 2013 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I have a 42" mtd lawn tractor. The blades do not
The blades engage via a belt, that goes around a series of pullies, one of those pullies is a tension pulley that is connected to your pto lever by springs, the engine has nothing to do with your blades until after you engage the lever, I would check your belt. It could be loose, and if you engage the blades it could take it a few to get up to speed, thus making it seem like its only when the engine is warm.
Does everything else work fine? As in the tractor moves when the blades are not engaged?
Jul 11, 2012 | Garden
How too replace the blade drive belt on a murray lawn mower
Its actually really easy. First, determine the size of your mower deck. Is it 30" 42" 54" etc. Then, go to a home improvement store like Lowes or The Home Depot (or an online retailer.) Search for a replacement belt for your deck size. Removing the old one is easy. Pry back the retainers on the engine pulley and slip the belt off of the pulley. This should make it very easy to pull off the mower deck. Installation is the opposite of removal. Make sure you note the belt arrangement for proper installation. Good luck!
Jul 09, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Apr 25, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Car Audio & Video Logo
44 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
