Seat Belt Extender: Fits 2007 BMW 328i Rear Middle Seat Logo
R
Richard Bartley Posted on Aug 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace Rear seatbelt in 2005 Ford Ecape is stuck
I removed the seat to relieve tension and it still would not release
BlownBlueZ06
Level 2:
New Friend:
  • Expert 40 Answers
  • Posted on Aug 10, 2014
BlownBlueZ06
Expert
Level 2:
New Friend:
Answers
40
Questions
0
Helped
7570
Points
105
I've repaired a few seat belts in the past. Depending on where your mechanism is located, you need to get to it and remove it. Every one that I've repaired had a locking mechanism that is based on G forces and I've removed the side cover of the seat belt to release it. If it's a SRS seat belt, be careful to not trip the circuit. Do your work with the battery disconnected. Once you get the seat belt mechanism apart, small screwdrivers and a pick set would be the best tools to have on hand.
Is it possible for me to unlock my seatbelt that has been stuck around my headrest
First off, are you able to move the seat forward, backward, or upward to free up the tension on the seat belt lock so you can again pull out slack? If not, are you able to raise or remove the headrest to create slack in the seatbelt and release the lock? Without a photo of the situation it's difficult to understand how you managed to get a seatbelt stuck around a headrest....
How to get 2005 Ford Escape Rear Middle Seatbelt to release?
It takes a special key - that's a safety feature for baby seats.
The back left seat seems to be stuck due to the locking of the middle seatbelt. Any idea on how to fix that?
When a seatbelt locks up it is usually due to dirt or corrosion in the automatic locking mechanism. The mechanism can't release because it is under tension. If you get into the cover that houses the release mechanism for the seatbelt, you may be able to hit it with a little wd-40. You do have to release that tension so that the lock will spring back to the open position and allow the seatbelt to retract. Try the lube. Sometimes the galvanized coating on the internal parts causes a seize.
Middle back seat: seat belt is locked up & will not release!!!
DO NOT CUT YOUR SEATBELT!!! Simply unbolt the seat from the body, unbolt the seatbelt from the body under the seat, tilt the seat forward, pull the seatbelt and part that attaches to the body between the seat cushion and backrest and release the tension. Not the easiest fix, but it only takes 30 minutes to do, and will save you a LOT of money. If you cut that seatbelt, you will be buying a new rear seat.
2005 jeep grand cherokee hello the middle seatbelt in the rear seat middle is not coming our I am unable to use the seat belt seems like it is stuck what can I do to try and fix the problem without...
You can unbolt the belt at the bottom under the seat. Its kinda hard to get to. Its connected to the left side belt release. Once unbolted you can replace the part. Or if you want you can atleast get it to release by letting it go all the way to the top. The only problem with that is the problem will come back.
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Rear seatbelts jammed down backseats
hello tracieandmia, I am assuming that the seatbelt buckles are just underneath the seat. The rear seat bottem can be removed for access. If you reach under the front part of the seat bottem near each corner and lift up, the seat will release. You will need to give it a little yank and use a little force for it to release. Once each corner is released you can remove the seat bottem. To install the seat, slide it back under the seat back and push hard down on each front corner that you had previuosly pulled up at. You should hear a definite click/lock sound when the catches are locked.
1helpful
I have a 1997 Ford Escort. The rear seat belt is stuck
make sure that the rear seats are properly locked into rear catches as this can stop your seatbels from working if ok then sounds like your seatbelt is faulty req new seatbelt.
Rear seatbelt
fold rear down take outter seat off one twelve bolt at bottom remove clps and pck tray YOU GOT IT
Top Seat Belt Extender Pros Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Seat Belt Extender Pros Vehicle Part and Accessory Expert? Answer questions, earn points and help others
