Question about Brother MFC-7820N Printer
How to remove a fuser - Brother MFC-7820N Printer
Posted by Rich Principe on
How do I Fix HP Printer 50.9 Fuser Error online ?
50.9 Fuser error message HP LaserJet P4014 P4015 P4515 If you are seeing the message 50.9 Fuser Error on your HP LaserJet P4014, P4015, P4015 series printer, you have either a failing fuser or the wrong model fuser installed in your printer. (The fuser is the consumable part in your printer which heats up and bonds toner to the paper. Usually the fuser gets replaced several times over the life of these printers.)
HP makes 2 different model fusers that look very similar -- the P4014/P4015/P4515 series fuser, and the M600 series fuser. Because of the similarities in appearance, sometimes the wrong fuser gets installed in the wrong model printer and triggers a 50.9 error.
The easiest way to check which model fuser you have installed is to pull the fuser out of the printer and look at the fuser's barcode. It is easy to remove the fuser on these models; if you don't know how to remove your fuser see the removal instructions farther down this page.
Once you have the fuser removed from the printer, look at the barcode as shown below to determine which model fuser you have installed. For the P4014, P4015, P4515 series printers the fuser part# should read RM1-4554 as shown in the picture below.
Either way, whether you have a failing fuser or an incorrect fuser on your LaserJet P4014, P4015, or P4515, you can purchase a quality replacement fuser in the maintenance kit for the P4014, P4015, P4515 series. Click here to view our selection of fusers/maintenance kits. Call us with any questions toll-free 866-352-7108 or local 608-831-2396.
Removal instructions: How to remove the fuser from the printer
Turn the printer off and unplug the power cord. The fuser might be hot if you have been using the printer. As a safety precaution wait 30 minutes for the fuser to cool before proceeding.
If a duplexer is installed, remove it from the back of the printer.
Next fold down the rear door.
Flex the plastic arm-hinge (circled in red below) on the left bottom of the door . This will release the tab which holds the plastic arm in place, and will free the door.
While grasping onto both sides of the fuser, push the blue levers upward and pull the fuser straight out.
After you order a replacement fuser and it arrives, you can install the fuser by inserting the fuser and aligning the left side first. Push the fuser firmly on the left side, then the right--listen for the sound of both blue levers clicking into place. If the fuser does not click into place you run the risk of wearing out both the fuser and the gears that drive the fuser prematurely. Re-install the plastic rear output bin and you are ready to print.
Dec 28, 2017 | HP Office Equipment & Supplies
How to fuser chnge
1. remove the cover for the duplexing drawer below the fuser drawer.
2. extend the fuser drawer
3. remove the 3 front covers of the fuser drawer
4. remove the three black screws that secure fuser motor,
5. remove the yellow cover to access then two screws that secure the fuser unit to the drawer.
6. unplug the connectors you see in front and the one below the fuser unit.
7. fully extend the drawer and push in the leaf springs you see and pull the drawer out further
8. remove the two screws you see on the top of the fuser and remove the fuser unit- gently.
Good luck
Jul 11, 2014 | Canon LASER SHOT LBP 3300 Printer
How to reset fuser kit on X656de
  • 01: Lift the paper bail, and then remove the fuser wiper cover
  • 02: Remove the top rear door
  • 03: Open the fuser cover
  • 04: Remove the fuser
  • 05: Remove the new fuser from the packaging
  • 06: Insert the fuser
  • 07: Close the fuser cover
  • 08: Attach the top rear door
  • 09: Lift the paper bail, and then insert the fuser wiper cover
Or watch this video
Lexmark Product Videos
click on Service Maintenance
then click on Replacing the fuser
Manual X651de X652de X654de X656de X656dte X658d X658de X658dme X658dfe...
May 11, 2014 | Lexmark X656de AllInOne Laser Printer
Changing the fuser for a CM1415fnw
If your capable of searching google, you may want to grab the service manual for this, heres the procedure to change it out but as you can see there are even more procedures along the way...
Fuser 1. Remove the following components: ? Right cover. See Right cover on page 17. ? Right-front cover-1 and cover-2. See Right-front cover-1 and cover-2 on page 20. ? Control panel. See Control panel on page 22. ? Left cover. See Left cover on page 25. ? Document-feeder and scanner assembly. See Document-feeder and scanner assembly on page 28. ? Rear-center cover. See Rear-center cover on page 30. ? Rear-upper cover. See Rear-upper cover on page 31. ? Speaker. See Speaker on page 33. ? Top cover. See Top cover on page 34. ? Rear door and rear-lower cover. See Rear door and rear-lower cover on page 41. 2. Remove two screws (callout 1) and the black plastic cover (callout 2). Figure 1-117 Remove the fuser (1 of 4) 1 2 80 Chapter 1 Removal and replacement ENWW 3. Disconnect five wire-harness connectors (callout 1). Remove the wire harness from the guides (callout 2 and callout 3) and one retainer (callout 4). Figure 1-118 Remove the fuser (2 of 4) 2 1 3 4 4. Remove four screws (callout 1). Figure 1-119 Remove the fuser (3 of 4) 1 ENWW Removal and replacement procedures 81 5. Remove the fuser. CAUTION: Handle the fuser carefully. The sensors that are mounted to the output side of the fuser can be easily dislodged. When the fuser is reinstalled, make sure that the sensors are present, and correctly fastened to the fuser assembly. Figure 1-120 Remove the fuser Hope this helps...
Feb 16, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
Paper is stuck under the thermal unit and cannot be removed. The unit probably has to be removed to get at the paper and we need instructions how.
First you must remove the cover for the duplexing drawer below the fuser drawer. It will allow you to fully extend the fuser drawer to remove the fuser unit. You have to remove the 3 front covers of the fuser drawer, remove the three black screws that secure the fuser motor, then the yellow cover to access then two screws that secure the fuser unit to the drawer. But you must unplug the connectors you see in front of the fuser unit. I believe there are 5 connectors that need to be unplugged. Don't forget to unplug the connector below the fuser unit. This is the sensor that tell the fuser shield its home position. You fully extend the drawer by looking at each side of the drawer and push in the leaf springs you see and pull the drawer out further. Remove the two screws you see on the top of the fuser and gently remove the fuser unit. Take your time and all should go well.
Jan 15, 2011 | Canon imageRUNNER 5570 Copier
Laserjet4 50 intervenire
X FUSER ERROR A fuser error has occurred. 1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Apr 07, 2010 | HP LaserJet 4 plus Printer
I want to fix my Hp laserjet 2840 (Fuser error 50.2)
Oct 30, 2009 | HP Office Equipment & Supplies
How do I get to the Fuser Film on this printer so I can replace it
This is a complex job. Side panels are clipped on only & need to be removed first. Then remove front cover ( is clipped at top ). Then remove top cover & rear cover ( screws ). The fuser is now visible & there are about 2 or 3 screws on each side that need to be removed before fuser will come out. Large Gear needs to be removed from L/H/S gear train before removing fuser. There are lugs on the fuser on both sides and little bit of pressure to frame & fuser will allow the fuser to be removed.
Then dismantle fuser & refit fixing film.
Oct 29, 2009 | HP LaserJet 1020 Printer
User error
FUSER ERROR:
Mar 27, 2009 | HP Color LaserJet 5550hdn Printer
How do I get the fuser out of the Canon PC 940?
Open the unit, remove the power supply cover in the back left by removing 1 ***** and releasing two hooks. Remove 2 *****s securing the fuser. The *****s are located just in front (inside) of the fuser.
Disconnect the fuser power cable and logic cables and then rotate the fuser up and toward the exit area. The fuser should just lift out.
You can then open the fuser by removing two *****s and releasing two release hooks. This should allow you enough released tension to remove your transfer. Be careful not to damage the fuser film.
Mar 08, 2008 | Canon PC-940 Black and White Copier
Brother MFC-7820N Printer Logo
88 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
