After the wrinkle care cycle completes, the dryer stops, but the dial never advances to the "off" position. Is it out of sync?
SOURCE: GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
SOURCE: after 2 new drum plastic slide plates were
There are 4 glides on the top of the dryer which are set in the white plastic bearing. You may have needed all 4 not just 2 and/or you may also have needed the bearing if the glides were not replaced right away and they wore through the plastic.
SOURCE: The dryer starts without using the start knob when
Assuming that you have GE dryer DBXR463ED0WW,
Sounds like there is a couple of problems there:
There should be a schematic diagram inside the control panel, use it to for diagnosing the problems you described.
Good luck,
Vlad
First Choice Appliance
