Dyson Air Multiplier 10" AM01 Bladeless Fan - Satin Iron/Blue Logo
Question about Dyson Air Multiplier 10" AM01 Bladeless Fan - Satin Iron/Blue
How does a bladeless fan work - Dyson Air Multiplier 10" AM01 Bladeless Fan - Satin Iron/Blue
John Ireland
  • Dyson Master
  • 2,355 Answers
The air is drawn in by a fan in the base and then directed up into a ring. It comes out of a crack all around the ring and passes over a shape like that of an aircraft wing. Industrial designer Sir James Dyson named his fan the Air Multiplier
Posted on Aug 10, 2014
My bladeless fan has an intermittent fault, sometimes not turning on. If I lay it down and roll it back and forth this usually fixes it. Now there's a green symbol flashing next to the speed number.
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
4answers
Dyson bladeless fan not working. Lights on - nothing else
Dyson are over price made in china product and has lots of problems buy cheap regular fan
My Dyson Bladeless Fan/Heater is displaying E7 after a few minutes of running and then shuts down? It is brand new (a couple of months old) and been run about 3 times.
Hi Michelle, it's Jack at Dyson.
If your AM05 Hot + Cool heater is displaying the E7 error code, the best course of action is to contact us directly for further assistance. To diagnose the cause of the issue we would need to understand more about how the heater is being used - we should also be able to suggest a suitable resolution.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
2answers
Why wont my dyson fan oscillate?
Hi there, it's Jack at Dyson.
Your Dyson Air Multiplier AM01 desk fan should oscillate when you press the oscillation button on the base:
If you find that it's not oscillating when this is pressed, we'd need you to contact our Support team directly - we can confirm if we're able to resolve this for you under our free 2-year parts and labour guarantee.
You can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
My bladeless dyson fan frequently does not work. When you turn the power button on the light blinks blue. I've only had it a month
A blinking on/off switch LED light can indicate an interruption to the power supply. However we'd appreciate the chance to check your machine is working correctly - it sounds as if it should be well within our 2-year warranty period.
Please get in touch directly so our experts can help. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dyson AM01 fan can not on
Hi David, it's Jack at Dyson.
If your AM01 Air Multiplier desk fan doesn't seem to run at all, we'd appreciate the opportunity to take some further details - many issues are easily resolved with some troubleshooting checks over the phone.
In the event that we're unable to resolve the issue, we can confirm if a repair or replacement is covered under your machine's 2-year warranty.
You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dyson bladeless fan circuit burned out
First, you need to make sure that the faulty component is the ceramic capacitor. Then check to see if it's broken.
Use the multimeter and read the voltage on the capacitor leads. The voltage should read near 9 volts. The voltage will discharge rapidly to 0V because the capacitor is discharging through the multimeter. If the capacitor will not retain that voltage, it is defective and should be replaced. (Source:https://www.apogeeweb.net/electron/what-are-ceramic-capacitors)
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
NOEL
NOEL
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
