Question about Ricoh Aficio SP C820DN Laser Printer
Sp c820dn laser Printer error sc561 problems???
Help me
paulfvincent
    Champion:
  • Ricoh Expert
  • 208 Answers
Replace the fuser. Then thermopile if it continues.
Posted on Nov 23, 2014
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: Ricoh SP C410DN error code SC306
Reaseat the cyan photo conductor
Posted on Feb 23, 2008
Anonymous
  • 111 Answers
SOURCE: cannot faind Ricoh Aficio SP C410DN Laser Printer driver
you can find the driver here http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11540&ricohmodelid=6342&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fcl410%2Fcl410en%2Ehtm
Posted on Mar 21, 2009
Anonymous
  • 63 Answers
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Posted on May 04, 2009
sethdileswar
Dileswar Seth
  • 253 Answers
SOURCE: i have ricoh sp c820dn printer and it dosent work
pls put the printer driver on drive (cd) and clik on set up file,,than installed it
Posted on Apr 05, 2010
gggg
  • 904 Answers
SOURCE: i have ricoh laser printer
sc270 is an error with the shutter on the laser unit. Turn the machine completely off and then back on -- if the error doesn't clear, the shutter sensor or motor will likely need to be replaced.
Posted on Mar 06, 2011
What is sc 565 on a sp c820
SC565
*Heat lamp consecutive on error
- Broken main fuser connection
- Check HR thermistors
- Heat roller lamp defective
- Power Supply defective
May 10, 2014 | Ricoh Aficio SP C820DN Laser Printer
Service call 582
This error is a fuser error .
The fuser is not set properly,remove the fuser and set in properly if the problem persists, fix in a brand new fuser.,
If the error appears again then call an expert to check on it for you.
Good luck
Apr 09, 2014 | Ricoh Aficio SP C820DN Laser Printer
ERROR code sc582
problem thermofuse heater stove
Jan 14, 2014 | Ricoh Aficio SP C820DN Laser Printer
My new Ricoh C820DN printer gives me a "waiting
please DO NOT use PCL printer drivers. USE RPSC or PS (post script) drivers and everything will be OK
pifonski
Feb 24, 2011 | Ricoh Aficio SP C820DN Laser Printer
Sc582
tengo un problema con la maquina ricoh sp c820 el error es sc582
Sep 24, 2010 | Ricoh Aficio SP C820DN Laser Printer
Ricoh Aficio SP C820DN Laser Printer Logo
106 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
