Question about Jet 3 Ultra Power Chair
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Pulled in onboard charger over night. Batteries did not charge
Mark Adkins
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Posted on Aug 25, 2014
4 Related Answers
lennieg2000
  • 692 Answers
SOURCE: Jet 3 Ultra, batteries 1 yr old, charge voltage
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Posted on Oct 31, 2010
Testimonial: "Thanks very much! I wa not sure if the charger was outputting enough voltage to charge the batts, You have confirmed that the batts need replacement"
Anonymous
  • 37 Answers
SOURCE: Jet 3 Ultra won't charge
You can find the Fuse behind the foot rest. Take the pin located under the foot rest, and the casing will come off exposing the fuse.
Posted on Jun 24, 2009
tbreeze47
Tom Carson
  • 3083 Answers
SOURCE: had not used the
You'll have to get to the battery terminals while they're charging, and then you can measure the charger voltage, if any (around 12 v).
It sounds like your charger is bad, and you can order one from this site:
http://www.monsterscooterparts.com/jet3ultra.html
Good luck, and hope this helps you.
Posted on Nov 07, 2010
kevin hinchley
  • 186 Answers
SOURCE: charging system on a Jet 3 ultra power chair
rectifier on charger
Posted on Aug 14, 2012
I have an Invacare Pronto M-91 Sure Step Electric Wheelchair that when plugged into wall socket is no longer charging chair batteries. The onboard Signet charger's led light isn't illuminating at all when...
The charger is defective. I would not try to charge it externally because if you charge it with a higher rate of current (amperage) than the original charger, it could explode or leak.
Jun 05, 2014 | Health & Beauty
Only the red light comes on jazzy select charger
Batteries must be stored on a full charge. For extended periods they should be disconnected. If your batteries are flat/dead the charger will not attempt to charge them. You should remove your batteries and check and try to charge them individually. Sometimes they will come alive, must of the time they won't. Charge them individually with a 12 volt 2 amp charger - no higher; or in series with a 24 volt 4 amp charger.
Mar 01, 2013 | Health & Beauty
Is there fuses in the M91 Pronto Onboard charger
I had this exact same problem after having my M91 in the shop. The repair man said that the onboard charger was bad, so he sold me an offboard charger to charge through the arm. That didn't change anything. I finally took it apart myself and discovered that there was a cord leading from the onboard charger to the batteries that the repair person had left unplugged when he installed my new batteries.
What I'd thought was "fast draining" of the batteries was actually the batteries self-charging overnight (which they will do a little bit if you let them sit). Of course, this might not be your problem, but I'd say at least look at it as a possibility.
Aug 23, 2012 | Invacare Supply Group Invacare Pronto M91...
I have a brand new scooter the batteries wont hold the charge
Bill have them replace the batteries. They are under warranty for 6 months and the provider is responsible for providing free replacement batteries under warranty. If they won't contact the manufacturer of the chair and explain your problem (that the provider will not replace bad batteries) they should require the provider to give you new batteries or send some to you. Make sure that you charge the new batteries before use and that you charge them nightly for 20 days If you use the scooter daily charge it every nite when you go to bed and unplug it in the morning hen you get up. Remember to have the power off to the charger whenever you plug or unplug it from the scooter. if the charger is an onboard one then just plug it into the wall and unplug when charged Hope this helps
Apr 08, 2011 | Electric Strider Mini 4 Wheel Mobility...
Invacare m51 scooter. I just replaced the batteries in my dads chair. We charged it all night the first night and it ran great the next day. recharged it for several days after using it and now the battery...
Sweet you do not need to leave the charger plugged in for several days. Sounds like there is a charger problem When you first plug the charger in with batteries depleted you should be getting a red and yellow light with the yellow turning green when fully charged. now the charger (built in) could have become unplugged from the power module located in the rear of the chair behind the black cover. To get to it you have to remove the seat, shroud and batteries then using a phillips screwdriver and adjustable wrench remove the black cover. The charger cord will be the last one on the left with a small 4 pin white plastic plug make sure it is well seated in the power module. If it isn't loose then you have a problem with the charger or the circuit. Now if you know of a friend that has an off board charger for a chair or scooter that you can borrow you can charge the batteries using the charger port located under the front of the joystick Plug the charger into the port then into the wall socket and let er rip Charge until the light turns green overnite is a good habit to get into If the onboard charger is bad I would suggest you by an offboard charger (cheaper) Now if Medicare paid for your Dads Chair then they will pay for any repairs even batteries and you can contact the provider that your dad got the chair from to see if they will repair it Hope this helps
Feb 17, 2011 | Health & Beauty
Chair dont take a charge
Get new batteries If your batteries are 2-3 years old its time for new ones. You can check the output of the charger by using a digital voltmeter Set the meter to 200 vdc and plug it into the two outter holes of the charger port with the charger plugged in you should read 27-30 volts. and with the charger unpluged you can aslo read the voltage of your batteries. fully charged they should read 25 -27 volts. If when charging you don't read 27-30 volts then the charger isn't working and you can get an offboard charger cheaper than the onboard just charge thru the charger port on the joystick. Hope this helps
Feb 03, 2011 | Jet 3 Ultra Power Chair
Controller has single flashing red light. how to correct fault ?
The batteries are low and need charging If after you charge and you still have the single red light then you need to replace the batteries
Dec 07, 2010 | Health & Beauty
My jet 3 has been sitting for 6 months, will the joystick light up when the onboard charger is in use. When I plug the onboard charger in the altameter raised to 3.5 and after charging for 12 hours drop to...
Hixx the batteries are too low to light up the joystick and no amount of charging will bring them back. Sorry you will have to get new batteries. You will need 2 U1 batteries. Hope this helps
Dec 03, 2010 | Jet 3 Ultra Power Chair
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Oct 30, 2010 | Jet 3 Ultra Power Chair
Should the onboard charger be plugged in 24/7?
I won't leave them on constantly. How about a timer for the onboard charger. Set it for 30 minutes a day. You get 3 1/2 hours a week and the batteries won't heat up.
Aug 06, 2009 | Boating
Jet 3 Ultra Power Chair Logo
561 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
