Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
SOURCE: Hoover Dirt Finder (light) not working
Good be a bad sensor, but if less then a year old, it is under warranty. I would take it in to a warranty repair shop and have them fix it.
SOURCE: my self-propelled windtunnel bagless hoover does not pick up.
Remove the dirt cup.
Remove the filter screwed in at the top of the dirt cup opening.
Remove the hepa filters on the side of the machine.
Clean all filters and re-install them.
SOURCE: Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
SOURCE: My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
