Computers & Internet Logo
A
Anonymous Posted on Aug 09, 2014
I have a belkin 600db that worked fine for three years connected to dodo then changed address and couldn't connect the belkin to dodo. A d-link wireless adsl router connects ok everytime. I have spoken to belkin about the 600db and they couldn't find the problem and unfortunately I have lost the receipt to return it. I just purchased an AC1800 belkin and connected it for two days via the d-link and it was working fine with over 8 devices connected. For some reason it will not link up so I bought a belkin N300 modem router and this will not connect to the internet at all with all the passwords correct and several resets. Is it possible that dodo internet doesn't recognize Belkin anymore?
Logan Simonsen
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Aug 13, 2014
Logan Simonsen
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
5637
Points
27
Have you contacted dodo internet? it might be that your ISP requires a PPPoE setup or something.
  • Logan Simonsen
    Logan Simonsen Aug 13, 2014
    Have you contacted dodo internet? it might be that your ISP requires a PPPoE setup or something. Just found this on their website "Connection Type: PPPoE LLC". I am sure you will need to talk to DODO for help configuring.
1 Related Answer
Anonymous
  • Posted on Aug 18, 2007
SOURCE: Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
3answers
Dell V510 printer worked fine wirelessly until we got a new Belkin Router
The printer's IP address most likely needs to be changed.
Check the Belkin's IP address range (it maybe 192.168.2.***) and configure the printer's IP address accordingly.
1helpful
Belkin wireless G router incompatible with netgear modem
connect your computer to netgear modem alone and check for the ip address in the computer
(make sure that you have selected "assign ip automatically" in computer)...
to open command prompt type "cmd" and hit enter in run box...
then you can check ip address by typing "ipconfig" in command prompt...
make a note of IP adress or ipV4 address found under the heading "ethernet adapter local area connection"
it might be 192.168.X.X
now connect only the belkinrouter and check for the ip address using the same steps above...
it might be 192.168.2.X
make a note of that...
now compare both the ip addresses if they both have the same value in first three places...that is
192.168.2.... or something like 192.168.1.... or 192.168.0.... then you are facing with double NAT issue...
all that you need to do for that is to change the ip address of belkin router...
if it is 192.168.2.1 change into something like 192.168.15.1...the issue will get resolved....if not you can reset the belkin
router by pressing and holding the reset button for 30 seconds using a toothpick when the power is turned on...
My laptop detects my network connection, I click connect then enter my password and when it is looking for the IP address the belkin router's wireless light starts blinking yellow. I never get connected....
Open RSP By typing 192.168.2.1 on the address bar of the internet Explorer
On the Left side Click on WiFi Protected Setup ( If its v 5000)
Leave the password blank and click submit
Disable it and click apply changes
It May Work
Problem connecting to router
Log into the Belkin router and make sure that the DHCP services are running. If it is, and you still are not getting addresses, perform a factory reset of the router. There is a link in the web management console to do this.
1helpful
One of five PCs not connecting to Belkin 54G router
I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
Cant play online games
Here are few things that you can try:
1. update the firmware on the router/modem
2. Open ports on the router/modem for P2P
Belkin wireless router not assigning IPs for wireless clients
Some routers start handing out DHCP wireless IP's at 192.168.2.100. Try setting the upper limit at .110. If the router is found in a site survey (view wireless networks) but cannot connect, the limitation would be why.
Unable to conect to dodo isp
First make sure that you have a valid connection to the router and that you have a valid IP address.
(note: for a wired connection you should have a link light on the numbered port of the router to which your computer is connected. You should have an IP address in the range 192.168.2.x. To check your IP address, click on Start, Run and type in command. Click OK. Now type in ipconfig and hit enter. Your IP address will be listed.)
For the F5D5230-4, F5D6230-3
Open a Web Browser
1. In the address bar type http://192.168.2.1
2. Click on Intial Setup
3. Select PPPOE and click Select
4. Type in your username that was assigned to you by your ISP *
5. Type in your password that was assigned to you by your ISP twice
6. Leave Service Name blank
7. Click on Enter
8. Click on Status in the left hand column
9. It should now show Cable / DSL Connected under the Internet column
For the F5D5231-4, F5D6231-4, F5D7230-4, F5D7231-4, F5D7231-4P, F5D8230-4, F6D3230-4
Open a Web Browser
  2. Click on Connection Type in the left hand column under Internet WAN heading
  3. Enter your password if any and click Submit
  4. Click on PPPOE and then click on Next
  5. Type in your username that was assigned to you by your ISP *
  6. Type in your password that was assigned to you by your ISP twice
  7. Leave Service Name blank
  8. Click on Apply Changes
  9. Click on the Home link at the top of the screen
  10. It should now show Connected as the Internet Status at the top right hand corner of the web page
3answers
Losing internet connection when I try to connect laptop to wireless router
Your cloning the mac address - thats the problem. It should use it's own mac address to connect to the modem. You need to power down the modem, then repower after a minute or so to let it connect to the new mac address. The problem you are seeing is due to network collisions betweenj the desktop and the router with the modem.
Grand Canyon Tech
Grand Canyon Tech
