Computers & Internet Logo
Posted on Jan 04, 2018
Recently my company installed ERICOM along with
Recently my company installed ERICOM Poweterm Web Connect along with Sonic Wall TZ 210. Our internet connection is often very slow. Speed test consistently shows 18down and 5 up. The tech guys initially thought filter was causing this, but apparently not. I am not a tech guy so I hope I described this well
Beniptec
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jan 04, 2018
Beniptec
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
Helped
2092
Points
31
How do i hook up a dcm sub 210 to a onkyo tz-rz 810 av receiver with hdmi inputs?
Hello, you do not use HDMI. You connect using an LFE cable from the Sub-woofer output on the receiver to the sub. Thank you, CB
Not getting any sound from a dav tz 210 home theater system
unplug from wall and allow it to sit for a few minutes. reconnect power and turn on. connect different devices to the system to check.
Sonicwall keeps dropping braodband connection
Bad ADSL modem at your ISP's end?
Deteriorated twisted-pair wires from the telephone-pole to the demarcation box on the outside of your home?
Dying ADSL modem inside your home?
First, try a different ADSL modem.
Then, call your Internet Service Provider, and get them to trouble-shoot.
Finally, switch to a cable-modem provider.
How to disable team viewer in sonicwall TZ-210?
You can disable Team-Viewer using Sonicwall TZ-210. This is process that you need to understand with some examples. Please visit " http://www.fuzeqna.com/sonicwallkb/consumer/kbdetail.asp?kbid=6038&catID2=110&catID1=143". This will help you.
Give me the procedure to block G talk. I have facing problem to block google talk,Skype & IM clients Please suggest me.
Praveen,
1. You will have to be administrator on the computer.
2. Start the Fire Wall and block all these sites there.
Problem in Sonic FireWall
Check with your ISP for whether they have blocked Port POP3 Port 25 or not. also allow (Open) this port in Sonic Firewall also.
POP3 Default Port 25 but many provider use different Ports so also make sure that you configured correct port.
1helpful
2answers
I am using Sonicwall Pro 2040. I am trying to connect Sonic Wall gateway but it is asking for pre-shared key instead of user and password please help me. regards pratap
pre-shared key is a must for connectivity. only after inputting this, you would be prompted with user id & password, if configured to.
Sonic wall 170 fequently goes on safe mode
Upgrade the firmware & see if u have all the security bundles upto date.
2helpful
Sonic firewall tz 170
for acess blocked websites proxy sites can be used.for example blocked orkut can be accessed by using orkut proxy www.powerscrap.com.you need to search for a proxy site for your needed website.
Top Ericom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Ericom Computer and Internet Expert? Answer questions, earn points and help others
