ubuntu.com Logo
Suzanne Travis Posted on Aug 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ubuntu problems How can I fix Ubuntu 14.04. On 09.08.14 I added an update to Ubuntu 14.04 and since then the screen is blank after rebooting. I have a windows 7 / ubuntu partition on my computer.I still have access to Windows.
  • 5 more comments
  • Suzanne Travis
    Suzanne Travis Aug 09, 2014
    I do not have any information about the update but I did notice a red and white circle with a diagonal line across at the top of my screen before updating. Again I have no details. I remember the update mentioned Skype.
  • Suzanne Travis
    Suzanne Travis Aug 10, 2014
    I downloaded the suggested software (EasyBCD) but was not really useful as it seems the programme seems to recognise partitions within windows (if that is possible)My computer is divided into two partitions Windows 7 and Ubuntu 14.04. They are totally seperate and do not recognise each other. Thankyou for trying. Suzanne
  • Glenn Smart
    Glenn Smart Aug 10, 2014
    Ubuntu will be on a partition (orm in a folder within Windows). I'm surprised that EasyBCD hasn't worked...it usually does. When you run EasyBCD in Windows, click on 'Linux' to identify your linux partition.
  • Glenn Smart
    Have a look on Ubuntu forums. You will find a solution (though I really am surprised that EasyBCD hasn't fixed things ... remember you manually use EasyBCD to identify partitions and OS's). This is an old link - you need to reinstall the Linux grub loader into Windows.
  • Glenn Smart
    https://sites.google.com/site/easylinuxt...
  • Glenn Smart
    https://help.ubuntu.com/community/Recove...
  • Glenn Smart
    (You could just reinstall Linux from the cd ...). And just in case you aren't aware, you CAN access all your Windows files from within Linux. Use the disk management tool, mount the partition .. just a single click.. You can use Linux to copy and paste between the 2 operating systems. The same doesn't apply Windows to Linux.. Windows won't recognise Linux at all)
Glenn Smart
Level 3:
  • Master 845 Answers
  • Posted on Aug 10, 2014
Glenn Smart
Master
Level 3:
Answers
845
Questions
0
Helped
274150
Points
3746
Download the free edition of EasyBCD (it's boot-up software) and install it in 'C' -Windows. Run EasyBCD... it's very straightforward. It will identify the operating systems on your computer ... choose 'use EasyBCD boot loader' (or similar) and save the changes.
It sounds as though you have somehow lost the boot loader for Ubuntu (it's in C - Windows) when there was an update, which is quite common ..
Using EasyBCD will return your computer to dual-boot
1 Related Answer
Anonymous
  • Posted on Dec 07, 2011
SOURCE: how do i get X P up on my computer after puting Ubuntu along side my X P home
when you install ubuntu, (or practically any linux) it will give you an option to shrink the windows partition - it then sets up a dual boot for you. Windows doesn't see linux partions at all - so the set up has to be down from the linux partion.
I have installed a Geforce 210 pcie card on my pc. After I install ubuntu 16.4.1 I get a blank screen with a red box in upper left corner. cant do anything else. Works fine with my older card
Download and burn recovery cd that boots into memory and not install.from here
https://www.system-rescue-cd.org/Download
when booted from it try finding correct video driver for Ubuntu or un install video driver and reboot
tip
Ubuntu 10.04 networking stopped after running updates
I had problems with Ubuntu 10.04 after running updates, After a lot of playing about and hunting around on the net I found the best way of fixing this is as follows:
click on applications, a accessories, then select terminal
now type sudo apt-get remove network-manager
now type
sudo gedit /etc/network/interfaces
you will now be able to edit the file
add the following 4 lines
auto eth0
iface eth0 inet dhcp
auto wlan0
iface wlan0 inet dhcp
now save the file and reboot your system.
You will now find your wireless and lan works
on Apr 02, 2010 • Canonical Ltd. Ubuntu
Installing Ubuntu Server on Dell Dimension 2400?
Step 1:
The Ubuntu Linux operating system is available either with or without a desktop environment. The version with the desktop environment is meant for personal use and includes word processing, email and graphic editing software. The version without the desktop environment is called "Ubuntu Server." The server version does not come with any graphical software or productivity software. There are three different desktop environments available for the Ubuntu operating system. The default is the Gnome desktop. The other two are the KDE and the XFCE desktop environments.
Log into the server. Type the command "sudo apt-get update" to update the list of software packages available. Type the command "sudo apt-get install ubuntu-desktop" to install the Gnome desktop. Type the command "sudo apt-get install xubuntu-desktop" to install the XFCE desktop. Type the command "sudo apt-get install kubuntu-desktop" to install the KDE desktop. Type the command "sudo reboot" to reboot the server. Ubuntu Linux Tutorials,Howtos,Tips & News http://www.ubuntugeek.com/install-gui-in-ubuntu-server.html
Motherboard posts, Windows 7 installed, all drivers updated, computer randomly throws up a blank screen while in Windows and I have to reboot. Onboard video problem? BIOS setting I'm missing? MSI...
well lots of cause for black screen , on the fly, w7 running.
i guess caps lock key dead too? showing that CPU is offlline if dead.
good fact there on Ubuntu.
but is Ubuntu on other drive or usb or DVD?
my guess is HDD is bad holding w7
as most are that the SATA is it?
nforce is bad news, there is no future support, a DOA EOL chip set.
but not your pc problems'
caps lock dead
control +alt + del , dead. too?
turn w7 sounds on (system sound)_
THEN AT BLACK SCREENED, unplug keyboard usb hear dingdongg , and reversed that.? if not dig windows is dead.
same with adding mouse or usb memory stink, ding?
or just wrong GPU driver loaded in to w7
last no GPU card installed now, use VGA local port does it fail w7
1helpful
How do i upgrade the OS of eee PC 900A to a netbook ubuntu 9.10?
download the image of ubuntu put it on a stick here you have two option uninstal the old OS or update if you want to update:
To upgrade from Ubuntu 9.04 on a desktop system, press Alt+F2 and type in "update-manager -d" (without the quotes) into the command box. Update Manager should open up and tell you: New distribution release '9.10' is available. Click Upgrade and follow the on-screen instructions.
To upgrade from Ubuntu 9.04 on a server system: install the update-manager-core package if it is not already installed; edit /etc/update-manager/release-upgrades and set Prompt=normal; launch the upgrade tool with the command sudo do-release-upgrade; and follow the on-screen instructions.more info on:http://www.ubuntu.com/testing/karmic/alpha1
1helpful
Gurb hangs after installing ubuntu on raid 0. I left a 500 Mb /Boot (marked as bootable), 1,7 Gb swap on each disk and /root and /home partitions on raid 0 disks each. Installation gave me no problems but...
I too upgraded from Ubuntu 9.04 to Ubuntu 9.10 using wubi, the Windows ubuntu installer. Everything was fine, and I even admired the beautiful desktop, added KDE. I was very impressed until came the time to reboot. Grub hung. I entered the console and tried to repair: To no avail.
I reinstalled Ubuntu/Gnome without installing KDE. All went fine until the time to reboot. It hung again. After several trials, I decided to go back to Ubuntu 9.04.
From what I could gather on the Internet, it has to do with the new type of file system ext4. If only I had the choice to use it or not.
Since I was using wubi and was not offered the choice to install the ext4 file system, I do not know whether that choice is offered on a full scale installation without wubi. You might try to find out if you can customize the installation process and not select the ext4 file system, if possible.
One remark concerning the amount of swap space you are setting aside. In my opinion that's too much: I have a 2GB RAM, about 300MB swap space, and each time I monitor swap usage I find it very low to nil.
Concerning Ubuntu 9.10, I will wait until the bug(?) is fixed before upgrading. Good luck to you
I hope it helps
Thank you for using FixYa.
Trying to run ubuntu
It sounds like Ubuntu chose a screen resolution that your monitor doesn't support. For the sake of sanity, I would a reboot and then try booting to Windows to ensure that what camone311 suggests happened isn't so -- I doubt it, as the install process is more involved than just 1 click - there are SEVERAL variables (time, date, username, passwords, how much of the hard drive to use, etc) that have to be set before anything is written to the hard drive.
If you're able to boot to Windows, then I would boot back to the CD and give it another go. At the menu where it says Try Ubuntu... there's an option to change the graphics modes - I would try safe graphics mode or VESA to see if that fixes the black screen problems that you were having.
2answers
Touchscreen calibration in ubuntu
The touch screen on these models do not have a calibration setting. They work or they don't. If it not working properly you can try uninstalling the drivers for the touch screen, then reboot. The machine will find the touch screen and reinstall the drivers automatically. Also check for any updated drivers at Panasonic's support site. Then check the connection for the touch screen, the touch screen has a separate connection than the screen, and it may have worked loose or have a little dirt or corrosion built up. If this doesn't work, then I'm afraid that the touch screen may be wearing out, nothing you can do for this.
1helpful
4answers
Ubuntu Install Problem
i gav encountered this prob while i was helping my frnds install UBUNTU......then i found out they had low RAM.....but if ur patient n wait for a lil longer it does work on som comps.....its better u upgrade ur RAM....
Top ubuntu.com Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an ubuntu.com Computer and Internet Expert? Answer questions, earn points and help others
