Question about Bunn NHB Coffee Maker
How to fix a leak on a bunn NHBX coffee maker
Leaks cold water from the the upper resevoir
RJ Keck
    Novelist:
    Scholar:
  • 166 Answers
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Posted on Nov 23, 2014
  • Mary Mar 19, 2015
    how do you remove the reservoir cover?
2 Related Answers
atbsmmom
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
If you will locate the date code on the bottom of the unit and then call Customer Service, the machine will be replaced at no cost or if over 3 years old, at a reduced price.
My Bunn nhbx-b leaks water when brewing coffee
you could remove the cover and look for the connection that isn't connected properly - - be careful not to touch electrical connections/bare wires when cover is off - or take it to a technician - or contact Bunn directly for suggestions.
regards,
Feb 11, 2017 | Bunn Coffee Makers & Espresso Machines
How to fix leaking Bunn coffeemaker nhbx-b
Check the couplings of the rubber hoses to/from the heating element.
Apr 08, 2016 | Bunn NHB Coffee Maker
HOW DO I STOP A LEAKING BUNN COFFEE MAKER NHBX-B
Go to UTube - there are some good videos out there on how to fix this. You have to take the top off and clean the flapper.
Jan 25, 2015 | Bunn Coffee Makers & Espresso Machines
How to remove the top water resivour from a nhbx bunn coffee maker
lift filler led and remove 2screws on top of reservoir
Then remove 4 screws that hold the reservoir on an you should be able to lift it off
Sep 03, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
Bunn nhbx leaks water
Jun 30, 2014 | Bunn NHBX
Bunn nhbx leaks out of the bottom
according to BUNN it is not repairable . they won't sell the parts needed
Jan 19, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
I have a bunn coffee maker the nhbx is the # it is leaking water from the resevoir
May 12, 2010 | Bunn NHB Coffee Maker
I have a bunn coffee maker the NHBX is the # it is leaking water from the resevoir
Mar 21, 2010 | Bunn NHB Coffee Maker
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn NHB Coffee Maker Logo
5,438 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
