This thing is about 30 years old and is pretty simple but I am new to electronics. How do I troubleshoot basic electronics? I have a multimeter.
SOURCE: simple loan payment
Reset your calculator.
Input the followinw:
-200,000 PV
5.75 I/Y
30 N
CPT PMT
Note: If the interest is compounded monthly then you have to multiply 30 by 12 and divide 5.57 by 12.
SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
SOURCE: Texas Instruments TI-30X IIS Calculator '+/-' sign
it is just a (-) symbol and it is beside the decimal point (.) button
SOURCE: my TI-83 plus calculator doesn't work
As battery gets drained, the screen contrast dims. But when you change batteries, some times the contrast is reset to some low value and the screen appears dead: it is so light that you do not see anything, and you think the calculator is malfunctioning. This is the most frequent reason users think the calculator refuses to turn ON. And I hope that is the case now.
To correct that, you must increase screen contrast: draken the screen a bit. To do so
If that solve your problem that is good, rate the post accordingly.. If that does not, do not get irate and berate the post. Post a comment here describing what you did and what message (if any) calculator returned, and I will give you further diagnostic steps.
SOURCE: replacing batteries on a ti-30xa
After the batteries are installed you
need to reset the board. There is a little reset area that needs to be
shorted to get the calculator back to normal. Look closely at the
circuit board- You'll see a little circle next to the word reset. Its
near the middle of the board. Wet your finger- press it on the circle.
It should short.Blow it dry.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
