You may need to UNSCREW the front half of you fan guard plastic casing or depress it in a few place if you see notches on the cage itself. Remember the knobs you will be removing to take the blades off to clean will be threaded opposite, one will screw off and on clockwise then other counter clockwise. Be sure FAN is UNPLUGGED BEFORE YOU open it up. Lay all parts in bathtub, Spray with Cleaning foam, pour lots of water over to clean all sides, then let drain and dry in bathtub. Less muss and fess this way!
SOURCE: my lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
If you need further help, Iām available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
SOURCE: Cleaning
Model E20739: The entire back comes off to expose the fan blades after removing two screws. Just unplug the unit. On the back of the unit near the top is a recess that acts as a carrying handle. In that area you will see two large silver-colored screws. Remove these, grasp the back of the unit and push down on it as you pull it away from the body of the fan. You may have to wiggle it around a little to free it.
SOURCE: how do i take apart and clean my 2517 lasko t.f.
I took mine outside and hosed it down real good and then let it air dry for a day or 2. worked great! it was filthy!!! and that dang screw made it impossible for me to fully take it apart to clean it, so I decided it was either the hose or throw it away. mine was incredibly dusty and i was able to use a hose with a power nose and spray it really good. we'll see how long it works :)
