Marantz SR5007 Home Theater AV Receiver Logo
Question about Marantz SR5007 Home Theater AV Receiver
What can i do to stop the red light blinking for marantz sr5007?
Whenever i switch on the receiver it automatically reverts back to red light blinking and does not go on. While in the process a speaker seemed to have blown. so what can i do to stop the red light blinking for marantz sr5007?
Posted by Pola Em on
claudio
    New Friend:
  • 44 Answers
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
buttons
Posted on Nov 21, 2014
5 Related Answers
cyrylthewolf
Cory Kielion
  • 143 Answers
SOURCE: Problem with Marantz SR5500 Receiver
Sounds like you have an issue with your electrical circuit. Your receiver could be receiving spikes of current from the electrical wiring in your house.
Review your current electrical situation. Keep in mind that certain outlets are on the same circuit and that running multiple, high-wattage devices on the same circuit can cause issues with some of those devices. Especially when it comes to turning devices on and off.
Many devices take a sudden, rapid charge to power their circuitry the moment you turn the device on. Home audio and HVAC systems are particularly notorious for doing this. Other devices on the same circuit can sometimes suffer influxes of power flow and may either turn off or go into standby mode to protect themselves from the resulting surges.
I've lost audio systems that way... I lived in an apartment building that has wiring most likely dating back into the 40's. I once turned on a space heater on it's max 1500 watt setting and blew my Logitech Z-680 speakers. (The "BOOM" sound that emitted from my subwoofer was AMAZING. I had just blown an amp circuit. It literally exploded inside of the subwoofer. Took pics and everything.)
If you have the means to do so... You might consider re-wiring your electrical circuit. Take into consideration where you're going to run certain devices and wire the system accordingly.
In the meantime, you would want to be sure to buy a HIGH-QUALITY surge protector for the audio system. Spend a few bucks and get a GOOD one with a good warranty on it. Don't use those cheapy ones that we only really use to split the outlet. NOTHING under 1,000 joules.
My receiver sometimes locks itself like that, though. If we have a power outage or the unit is unplugged suddenly, it will keep itself in standby mode until you unplug it, press the power button a few times to discharge any current left in the capacitors and plug it back in normally. Only then will it turn on again.
Let me know what you come up with.
Cyryl
Posted on Nov 03, 2007
Anonymous
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
Anonymous
  • 8 Answers
SOURCE: Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Posted on Nov 04, 2010
Anonymous
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Posted on Apr 06, 2012
vk3uck
Nick Verdelet
  • 166 Answers
SOURCE: Marantz sr5007 power supply dead
Have you tried a protection reset on the unit ?
Posted on Jun 25, 2014
Surround left and surround back channel (speakers) not working.Changed wiring and speaker,problem still exist.
It could be they have been switched off accidently. Check the speaker settings.
1helpful
2answers
The red light on my Marantz SR5008 keeps flashing and wont turn on. How can I fix this
Disconnect everything and then plug in only the power. If the light still blinks, the PS is probably damaged and will need to be serviced. If the light doesn't blink, you have a shorted connection. Speaker wires are probably the most likely.
How to connect apple tv to marantz sr5007 receiver
Apple TV connects via HDMI to the back of the amp.
Marantz sr5007 receiver dead after lightning strike
Hi Ridgep.
Replacement of the TOP258MG IC Should resolve your problem. Make sure you have fully discharged all the caps on the primary side of the power supply before fitting your replacement IC as they are very easily destroyed during installation.
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Code for maratz sr5007
What is the brand name of universal remote control do you have?
Marantz sr5007 firmware update loop
hi am also having same issue, did you found the ans pls share me.
5helpful
3answers
iskender
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
