Question about Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator
How do i fit a handle to a liebherr fridge door
4 Related Answers
Anonymous
  • 269 Answers
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
Anonymous
  • 4793 Answers
SOURCE: Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
Posted on Jul 23, 2010
Anonymous
SOURCE: Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
Posted on Nov 03, 2010
My Liebherr CNes 3366 fridge freezer has started to build up ice in the bottom of the freezer. How do I check the fan in the fridge is working, (I never see it going)as it may be the cause? thanks r
remove cover and test with a meter or push door switch when door open and should hear fan hum or feel air when door open fan stops unless you push switch
Apr 20, 2017 | Liebherr Refrigerators
We don't have access to the back of fridge as it is fitted. what happens if we put bleach or milton into the drain-hole?
You can pour a 50/50 mix of bleach and water down the drain hole, but I wouldn't stop there. If you take off the front grill of the refrigerator, you will see the condenser coils with a tray under it. This is where things from the drain hole ends up. If you have a small long handled brush you might be able to clean it out.
Jan 02, 2012 | Liebherr Refrigerators
Hope this helps.
Jun 08, 2010 | Liebherr Refrigerators
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
I have a Liebherr fridge which seems to be on permanent supercooling. It freezes fluids. I try setting a higher temperature but it just drops back to 4 C
4c is the std operating temp for most fridges.have you checked the door seals for fit if an airleak occurs fridge will try to maintain cooling.....freezing salads.
Feb 11, 2010 | Refrigerators
Apr 22, 2009 | Liebherr K3660-20 Refrigerator
Liebherr fridge parts? The plastic on the glass shelf has cracked and I need to replace the shelf but I don't know where I can do this... I'm also not sure what model the Liebherr fridge is either...
There should be a tag with model # on it somewhere on unit. Usually in inside side wall of fridge section. Or maybe on back of unit. Definitely need model # to order part.
Sep 08, 2017 | Refrigerators
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
john h
Paul Carew
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
