Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
IntelliFAX 4750 Toner Empty
We just changed a new Toner because the screen displays Toner Empty. even with the new toner it still displays toner empty. any Idea why it does this?
Posted by tafer on
  • Anonymous Nov 09, 2007
    replaced toner in our brother fax and it still says that it is empty
  • Anonymous Mar 20, 2014
    How do you correctly change the toner in a 4820 Intellifax. I changed it once but it is still telling me to replace toner
Anonymous
The toner ended up being bad.
Posted on Dec 05, 2007
Anonymous
  • 56 Answers
Hi, have you changed the drum anytime soon? If so did you clear the message before installing the new drum? The only other option would be to try a diffrent toner. There is not toner reset counter like there is for the drum! So I would reset the drum counter and see what happens. Good Luck
Brother intellifax 4100 e display says to replace toner but cartridge is not empty. Is there a reset for the toner?
There is no reset for the toner. It uses an optical system where light shines through the toner. Shake the cartridge gently left to right to even out the toner and try again.
Jul 01, 2011 | Brother IntelliFax-4100e Fax
How do you change the drum on a Brother IntelliFAX 2920?
Open the front cover.Pull out the drum and cartridge unit.Unlock the toner from the drum with the blue clip.Take the new drum remove all the pacaging material insert the toner in the new drum.Replace the drum and toner unit back in the machine.While the cover is open,press the clear button.The machine will display "Replace drum yes or no" Select Yes.Close the front cover.
Dec 07, 2009 | Brother IntelliFax-2920 Fax
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Change toner
most likely its a defective toner unit, they have a chip on them that tells the machine when it was installed, and how much life it has remaining. if the machine doesn't recognise that its a new toner cartridge its probably a defecive unit. you should return the cartridge from where you got it and try another.
Jun 08, 2008 | Brother IntelliFax-2820 Laser Fax
Right side of faxes (or copies) have 1-1/2" black line
Try changing the Drum Unit again....it cannot be anything else besides a worn out drum cleaning blade.
Apr 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
open front cover, press "clear" and 1, that will clear the change drum soon error
Jan 14, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
1,164 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
