Question about Dell Dimension E520 PC Desktop
Setting up another laptop,to check a bad lcd screen
Blank screen on start up,would like to use another laptop to see if the screen is bad
Carlos Krue
    Scholar:
  • 175 Answers
First when you attache the Ac adapter are there any lights do you see any lights? sometimes there is a light by the connector (jack) where you attach the AC. Otherwise this might be a mobo problem. Have you try to attach an external monitor? The top of the question mentions a desktop E520 but below points to a LCD. I am assuming a laptop. If you have another laptop with the same LCD screen then you can take the suspected bad LCD and place it in the good laptop. Also you can take the good LCD and place it in the bad laptop. First read the first lines of the preliminary troubleshooting.
Posted on Aug 09, 2014
Blank display on HP dv2000 laptop
i suggest you dismantle your laptop and take a look at the LCD cable behind the screen and make sure it is click locked.
Jan 23, 2013 | HP Pavilion dv2000t Notebook
Blank screen when powing on, won't start.
Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
Product Features:
1. Model: Toshiba laptop LCD screen
2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
3.100% new high quality replacement Toshiba laptop LCD screen
4. Toshiba inverter can be used for the other models and Inverter part No
5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
Nov 01, 2012 | Toshiba Computers & Internet
Screen is blank, it wont come up nor display anything but the power button works.
Try connecting an external monitor to it. If it display correctly, than check your display setting to ensure you have your laptop monitor as your default. If those setting are correct than you will need to open your laptop case and check make sure the connection did not come loose from LCD monitor to your motherboard. Use a small flat head screw driver to popup a cover right above your keyboard to get to the connection. If the connection are good than it may be a bad LCD screen or motherboard.
Jan 09, 2011 | HP Compaq 6735s Notebook
There is a white blank screen when i turn on
A white blank screen usually means that there is no data reaching the LCD. This can be caused by a bad video card, bad cable, or bad LCD. Rarely, the cable is just unplugged on either the back of the LCD or on the system board (or video card if separate).
Apr 25, 2010 | Computers & Internet
Laptop display goes blank after a second, not lcd inverter
I have had a similar issue with an LCD monitor and the issue was not with the inverter itself but the backlights. They can go bad and short (which is where my issue was. Once they were removed the screen was working again (the lights needed replaced).
Hope this helps!
Nov 08, 2009 | HP Pavilion tx2500z Notebook
Blank LCD screen on Compaq n800c laptop
First instinct would tell me that your LCD has gone bad. A refurbished replacement LCD should run around $300-$325 give or take.
Keep us posted, good luck
God Bless
-Carlos:
Jul 09, 2009 | Compaq Evo N800c Notebook
Screen keeps blanking out on my Dell Inspiron 1501 :(
could be a bad inverter board in the lcd that is easy as hell to fix
Jun 28, 2009 | Dell Computers & Internet
Satellite 1115 blank screen at start up.
Try using an external monitor. If an external monitor works then the issue may be backlight if not then the issue is the LCD screen. the way to test that is after you have used an external monitor to verufy booting and the the system works. then if the machine is out of warranty you remove the bezel anf the screws holding the lcd in place. lean the lcd forward. with a flash light on turn your system on and flash the light through the display if you see your post and or windows with the flashlight then the baclight is bad. if not lcd is bad. If you can not get teh external monitor to work, then your motherboard is bad or graphics card.
Dec 02, 2008 | Toshiba Satellite A100-S8111TD Notebook
Lcd screen
this can be a few different problems
1) one the simplest is a loose video cable beween the mother board and the LCD.
2) bad inverter or back light if in a split system mostly on some wide screen models.
3) a bad display
May 15, 2008 | Toshiba Satellite P100 Notebook
Laptop HP Compaq nx9420 Screen goes Blank
From the Symptom you described, it seems like the thin video cable's connector is loose and is barely connected to the video adapter on the motherboard. You won't be able to tell until you remove the Keyboard and/or the Palmrest to check it. Also, there is a slim possibility that the Laptop has knocked something loose and is going into sleep mode. Normally, a Laptop user can configure it to go into Sleep mode or 'Hibernate'. These settings can be found in the Control Panel under 'Power Settings'. http://www.Computer-Repair-Today.com
Jan 06, 2008 | HP Compaq nx9420 Notebook
Dell Dimension E520 PC Desktop Logo
26 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
