Startup of laptop and "BOOTMGR is missing" pops up. normal startup not happening
SOURCE: I turned on my laptop and it says bootmgr is
You need to repair your Operating System to fix this issue. Follow the steps,
* Insert the OS CD/DVD and reboot your system.
* Press any key while the system reboots to load the OS through CD/DVD.
* Select Repair. Once all the files loaded again it will automatically reboot your PC.
* Remove the CD/DVD and check whether its working or not.
Please let me know...
SOURCE: at startup it reads BOOTMGR is missing can it be
You will need a operating system disk or a repair disk to fix it.
Insert it in the drive then boot from it. You want to get to a dos
command prompt (black screen with white lettering) and type the
following commands. Press ENTER after each command. To run the check disk utility you will need a repair disc or
a operating system disc. Put the disc in the cd drive and boot from
it. You want to get to the Dos Command Prompt (Black screen with white
letters) and type the following command: chkdsk /r
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
