Question about Fuji FinePix Cameras
Why won't lens pop out when turning on? - FinePix Fuji Cameras
I dropped my Panasonic LumixDMC-ZS19 and now when I turn it on, it cycles, but then says Zoom error and won't pop out the lens. Help! I need it!
Hi, it looks like you have damaged the zoom mechanism that's why it will not zoom out . The unit will have to be repaired best to get a quote for repair first.
Jul 16, 2016 | Panasonic Cameras
I have a vpc-E1500tp and it won't turn on and it won't charge... What do I do?
Lens is not all the way extended, so you can not turn it on. the defect maybe fixed buy pushing on the power button and pull the lens out gently by wiggling the lens? It may all be futile. Buy a new camera.
Mar 30, 2012 | Cameras
My Samsung SL202 won't turn on at all and the lens is popped out. It is fully charged. Any suggestions?
something wrong with your lens, send it to the camera maintance center, then you will get the answer immediately.
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:[email protected]
cindy
Aug 19, 2011 | Samsung SL202 Digital Camera
Lens was stuck popped out
try using energizer battery more than 2000ma
May 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
The Lens wont pop out
Dear
Most probably your battery is low, if not then control circuit has been malfunctioned. Sorry
Jan 30, 2009 | Kodak EasyShare V1233 Digital Camera
Lens pops in and out
hi there
turn on and gently take the end of the lense pul it toward you and twist left to right a few times, be gantle dont make it pop you may however here it click. then turn camera off and on again and the problem should be solved.
Oct 31, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lens
The lens will pop up on certain settings, like the night settings
Aug 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Cameras Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
