Question about liftmaster Lift Master 377LM 376LM 315 MHz Garage Door Opener Wireless Keypad
How to change code on the garage door opener and the remote control on a lift master garage door opener
Remote opener has been lost or stolen need to change code on opener and remote
Kevin Kodama
  • 37 Answers
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Posted on Aug 21, 2014
  • Kevin Kodama
    Kevin Kodama Aug 21, 2014
    Pull the emergency release cord and lock the trolley open.
5 Related Answers
Norman Worley
  • 1273 Answers
SOURCE: garage door will not close when using the remote
Check to see if your child/animal security beam is working correctly. It is an "Electric Eye" mounted about 12 in off of the floor on two mounting points and one side shoots an infra red beam across to a receiver. These points must be reasonably aligned to flash a beam (cannot see) from one point to another. This beam keeps the door open if it is interrupted . If it is not aligned, then the door opener sees a problem and will not close the door electrically. You must aligned the beam by bending the transmitter or receiver untill you can close the door by the remote. Also check to see if something placed in the garage is not blocking the beam first.
Posted on Jan 06, 2011
Anonymous
  • 113 Answers
SOURCE: have a 2006 Liftmaster professional 1/2 h.p garage
The opener should have an antenna wire hanging out of it. Did someone/something hang on it?
Posted on Feb 26, 2011
Mike
  • 4372 Answers
SOURCE: The remote opener in my far works, but the garage
Perhaps the wall opener control needs to be accepted by the opener, press the button on the opener head unit and then press the wall switch. Consider new batteries before you do so.
Posted on Mar 04, 2011
FaceTheFacts
Steve Burt
  • 245 Answers
SOURCE: the garage Remote control was working normally at
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Posted on Jun 06, 2011
Anonymous
  • 11 Answers
SOURCE: lift master cablesi removed the cables and doors
Please do not attempt to set the tension your self. Call a garage door service Co. Broken arms and fingers result. It is not worth the attempt. Those tension spring do all the lifting of the door and have to much torque to mess with.
Posted on Jul 29, 2011
Lift master remote not working
It seems that the reciever part is defective, likely to surge or lighting, you have to have that module replaced.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Apr 16, 2014 | Master Heaters Lift-master Sears Craftsman...
How do I program the garage door opener?
You post again, what the model is of the opener, the car model, it looks like this control is in a car.
Most times you need the garage door remote, then you have to hold a button and the remote button to sync the two.
What ever you are trying to program, if this is a car, you need the manual.
If you need more help, you need to post the model number of everything.
Not every car, every opener is the same at programing.
Imagine that, life simple.
Apr 03, 2013 | Building Materials
How do I change the code for the door opener and remote. I have a craftsman 1/2 HP garage door opener. I have door door openers and one remote with three buttons.
You cannot change the code of your remote or opener. It is set at the factory. If you have lost or have had a remote stolen and need to eliminate its possible use you can erase the memory of your opener by pressing and holding the smart/learn button for 6 seconds. That button is on the back of the motor unit near where all those white wires go. Now you need to program your remote by holding the large button down while you press and immediately release the smart/learn button.
Mar 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have a genie garage with two doors and need to change one to open, one of the doors that use to open another door. Other door is opened by bluetooth by autmobile. How do you change code on unit on ceiling...
Go to this site and follow the directions under "Replacing a lost or stolen remote" Then you will need to program your bluetooth.
http://www.aaaremotes.com/gegadooptr1.html
Feb 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Programming car remote using garage door opener remote control fo
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Jul 03, 2009 | 2003 Lexus ES 300
Need to change the freqency on a lift master garage door
Chance are they set there remote when you were using yours. To reset your opener you need to clear all the codes on the back of your opener itself there is a square button purple or red depends on how old it is. Press and hold that button until the LCD light turns off. Press your remote to make sure it has stopped working. Then press the button again only for a sec until the light comes on and starts to flash then press your remote button. Repeat for each remote.
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 51-C Camberline Gar. Door Remote Where can I find match
The klik-1 will code in to this opener. The directions on the manual are very specific, but if followed it will work. There is also a number for step by step help on the directions. Thanks BB
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener
unplug the power of your door opener for a few minutes and plug it back in. Try the remote control that you have and see if it opens the door. If it doesn't open the door, reprogram [learn] the remote control you have and that is it. The other remote will be useless ... and you just proved it to yourself!
Sep 13, 2008 | Kitchen Appliances - Others
liftmaster Lift Master 377LM 376LM 315 MHz Garage Door Opener Wireless Keypad Logo
360 people viewed this question
Top liftmaster Building Materials Experts
Terry Smith
Level 1 Expert
Mike
Are you a liftmaster Building Material Expert? Answer questions, earn points and help others
