Question about Konica Minolta Bizhub C220 Color Copier/Printer/Scanner
Bizhub c220 why does my unit keep saying print status is stopPrint?
Posted by Traci Laird on
Tommy Thomas
  • 430 Answers
Try unpluging unit to reboot if all fails reinstall software
Posted on Aug 08, 2014
Bizhub c 220 gives white streaks on prints. How could it be solved.
Try cleaning the print head windows using the cleaning tool inside the front door or alternatively take the print head unit out and clean the windows using some glass cleaner
Mar 22, 2017 | Konica Minolta Bizhub C220 Color...
Konica Minolta bizhub C220 error code C-D010
disable hard discor try to do physicall format in service mode
Feb 18, 2016 | Konica Minolta bizhub C220 Color C / M / Y...
I have Konica c220 a maassage : replace the Drum unit Black. There no broblem in print quality so how it reset
you replace the image unit when asking for a new one do so if not it will cause problem when you need the machine most
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 19, 2015 | Konica Minolta Bizhub C220 Color...
Why does our bizhub c220 make a clicking sound all the time?
Sounds like the fuser unit is starting to reach the end of its life.
Sep 01, 2014 | Konica Minolta Bizhub C220 Color...
Printing black ground in konica minolta bizhub c220
have a tech come out clean the machine run require procedures to determine problem
Apr 26, 2014 | Konica Minolta Bizhub C220 Color Copier
How to clean transferbelt in bizhub c220
Remove the transfer belt unit,remove the upper cover and used a vacum cleaner,cleaning under transfer belt cleaning belt section.
Jan 26, 2013 | Konica Minolta Bizhub C220 Color Copier
We have a bizhub c220 that keeps wrinkling a3 paper. The engineer blames moisture content of paper but the paper has been in the machine for over a week and the room is bone dry. Help.
Try A4 R position and A4 normal position.If is OK the problem is located in the vertical transport section.If the problem persist the A4 paper the causes is located in 2 section:before enter in the fusing unit or exit to fusing unit.Check the Lower pressure roller and the springs.
Jan 22, 2013 | Konica Minolta Bizhub C220 Color Copier
Konica Minolta Bizhub C220 Color Copier/Printer/Scanner Logo
123 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
Marvin
Marvin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
