How to replace drive belt on john deere lt180
SOURCE: Replacing traction drive belt for John Deere L118
Actually this is a fairly easy looking one to replace. If you go to John Deere parts and do a search for your tractor, in the parts listing it gives a pretty clear picture of the routing and configuration of the belt as it should go on, you might want to print it out to have nearby while you are working on it. You will need to remove the mowing deck to get at it and possibly some large blocks to elevate the tractor to give yourself room to work.
Look closely at the old belt if it is still on the tractor to get an idea what is involved BEFORE you start, comparing it with the picture. You will need to loosen and move or remove the belt guards and do be careful of the nylon fan on top of your transaxle
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
SOURCE: LA150 john deere riding mower transmission slips
this transmission is a sealed unit, no way to add fluid or change filter.
SOURCE: need diagram to replace belt
See if this is even remotely close to your mower deck:
http://opebycrigby.tripod.com/decks/jd/jd48edgew.jpg
Also see if you can locate the mower deck model number i.e STX 38, STX 42 (Deck color Black or Yellow?) Should be a silver decal with black lettering. Also... there is supposed to be a belt routing diagram on the mower deck. (Another silver decal with the belt routing picture)
Kelly
SOURCE: i need a diagram that
hi there pauly46 here
type f725 in the search box - under j/d cataloue
here is web site adress to go to that page
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=f725
select f725 ,select sectional index , select mower deck and lift linkage,select mower drive belts sheaves and spindles ,
then a window with deck parts and diagram will appear
print this off
it will give a good idea of belt routing for deck
take a look and hope it helps
cheers pauly46
