SOURCE: ran out of gas-truck won't start-replaced fuel
you probably have air in the lines, if you have a carb, spray some quick start into the carb and turn it over, if it starts and then dies when the starting fluid has run out, you probably need a fuel pump, since the running of the car should have blown out any air that was in the line, If your car is fuel injected, loosen the bolt cap at the end of the injector line that supplies the fuel,, and tap the key once,, ( don't start it,, ) just turn the key on and off 3 or 4 times, this should blow fuel out of that loose bolt head, if it does your getting fuel, if not, back to the fuel pump, also you can check this link, http://www.aa1car.com/library/us1296.htm
