Question about XM Radio (XMP6000)
Why would my My Car Radio in my Hyundai Getz SXI switched itself off whilst I was driving
I then parked the car turned the engine off - turned the car back on and still nothing
Cedric Zumwalt
    Sergeant:
  • 209 Answers
Check the fuse. There should be a fuse for the radio, either in line or in the fuse box.
Posted on Aug 08, 2014
1 Related Answer
Anonymous
  • 72 Answers
SOURCE: My 6000cd radio in Ford Focus switches itself on
check your wiring if the car is off and the key is not on the radio should not have any power to it sounds like you have a wiring problem to me
Posted on Aug 07, 2009
How do I find the radio code for a Hyundai getz 2008 1.6
from your dealer need to notify them with vin and proof of ownership
Sep 07, 2016 | 2008 Hyundai Getz 1.6
How do I find out if it is a 1.6 or 1.4?
Hi Carol, Your registration paper should have your engine capacity on it......CHEERS..
Apr 08, 2016 | 2008 Hyundai Getz 1.6
Engine light appears in car after timing belt replaced
engine lights also look after the transmission so check all wire connections and vacuum hose to the gear box.
Mar 09, 2015 | 2011 Hyundai Getz 1.1
Steam comes out of the air vents Hyundai getz
Sounds like the heater matrix has been damaged. Turn the heater to cold to see if still happen. If it stops, took under bonnet/hood to see if its coming out in engine bay.....
Apr 07, 2014 | 2005 Hyundai Getz 1.6
Constant loud humming from front of hyundai gets
If the noise get louder as you speed up, it is possibly a wheel bearing, needs checking out by a mechanic.
Jan 27, 2014 | Hyundai Cars & Trucks
What doesn't a computer diagnostic pick up on engines in hyundai getz 2006 Sxi
check cigarette lighter fuse it controls cpu link or check scanner for proper update for vehicle
Dec 28, 2013 | 2008 Hyundai Getz 1.6
Where is the reverse light switch located on hyundai getz hatchback
Try underneath the car, The switch is located on the top right side of the transmission housing. the switch is located very close to the exhaust pipe.
Nov 20, 2012 | 2008 Hyundai Getz 1.6
Car Audio & Video Logo
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
