KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
This stove should absolutely still be under warranty. I would start with calling the KA customer service. They are pretty good and will usually do all they can to help you. The number for them is:
800-422-1230
I think I know it.
Modern cookers have semi automatic ignition. Behind every knob there is a hidden switch and the switches are wired in "parallel". That means, when one button is put in "sparkstand", all plugs will spark. At least it should be.
In the youtube movie you can see how these switches are in a string.
So I suppose that the switch behind the button for the main burner does not work.
Fortunately, you still can lit that burne r with the other buttons.
Look at the movie, may be you can fix it yourself.
Hi, If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
i have an electric kitchenaid stove and on the panel it says that that there is a stuck key.everything works but the off bottom, the only way i can turn the stove off is if i turn the range off. i spoke to someone over the phone who said to try and reset the stove but i can't find a reset bottom is there any way i you can tell me where the reset bottom is or what i need to do to fix the problem.thanks a lot
