My DC59 wont charge or work, and a red light flashes at the bottom when I press the button. How do I fix this please? is the battery messed or is the defective with the product??? Can you help me fix my problem or should I contact Dyson?
SOURCE: how do i clean my dyson root cyclone vacuum
believe it or not i would use a long paint brush with a opened bin linner,, to collect all the dust,,,
you can wash your blue filter in plain water and leave to dry as u would pots n pans on the side,,
when u have cleaned the area around the cyclone.. close your eyes and blow into the cyclone.. then use another large hoover to remove access dust and rubbish that was in the cyclone,
hope this helps reguards lee.
SOURCE: My hand held Dyson vacuum will not charge. Every
My same symptoms are - after starting charge, Red light is on, then second light turns On. Then for a long time nothing happens. And later I have all three LED flashing.
I replaced battery and nothing changed.
Imeasured Power Supply voltage and found it 24.2v instead 28v as it stated on the label.
I opened it up and found that the three-lid chip marked 431 is faulty.
431 is a voltage shunt, which sets and controls output voltage.
You can use AIC431CUS or TL432 (TL431 has different pinout).
I replaced mine and volatge back to 28.25v and charger is now working as it should.
You can also use any TO-92 431 chip - there is enough room for it.
SOURCE: dyson dc 31 was working
check all conections are clean on the battery terminals,this link is for the manual,
http://media.dyson.com/downloads/UK/floorcare/Manuals/dc31_origin_manual_uk.pdf
SOURCE: my dyson dc 28 is not working...the red power
I'm sorry to hear you're having difficulties with your DC28. It's probably best if you get in touch with us directly so we can help you resolve this issue as quickly as possible.
You can call us free on 1866MYDYSON. We'll look forward to hearing from you.
Kind regards,
JackDyson Online Customer Support
