I need to find a replacement transformer on a Power Control Board for my RCA RTB10223 Blu Ray player. The only marking on the Transformer are "ER28-T003" then below that "ACT 3411"
RCA RTD300 DVD/VCR Home Theatre System Repair ...
www.fixya.com/support/p455536-rca...home_theatre_system/page-6
Recent RCA RTD300 DVD/VCR Home Theatre System System questions, ... Whatspecific Transformer do i need so i can fix the PCB for my Blu-ray player?
RCA 300W Blu-ray/DVD Home Theater System Repair ...
www.fixya.com/support/...rca...blu_ray...home_theater_system/page-5
RCA 300W Blu-ray/DVD Home Theater System - Black RTB1013 - Page 5 ... Whatspecific Transformer do i need so i can fix the PCB for my Blu-ray player?
RCA Home Theater System Repair Questions, Solutions ...
www.dqrkc.com/troubleshoot/rca/home_theater_systems/page-9
SOURCE: blu-ray + bose 3-2-1 system connection?
Connect an HDMI cord from the bluray player to a free input on your HDTV. Then connect the standard WHITE/RED stereo cable from the bluray player into the AUX input in the back of your 3-2-1 system and voila!
You may need to check the configuration of your bluray player to make sure that is outputting stereo audio, for this please refer to the player's user manual. Other than that, you should be alright.
SOURCE: Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
SOURCE: Samsung blu-ray player won't eject, tried turning off power strip
I had a similar problem with my unit. every time i hit "eject" the screen would display "eject" for about a minute then display "loading" indefinitely. no mater how many times i powered on or off it just would not spit out my disc. However, I hit the "function" button on the player and cycled through radio, aux. etc. and that seemed to un-freeze it. I was able to eject my DVD while the player was set to radio. give it a try and hope for the best.
SOURCE: LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
SOURCE: My Samsung HT-BD7200 will not play blu-ray discs.
Hi there, this is a classic sign of the blu ray diode in the player becoming faulty. As with all blu ray players the technology is basically the same and the symptoms you describe are identical to all other blu ray drives. There is a small chance that you may be able to get the blu ray diode replaced but this can be costly so you need to weigh up whether or not this would be economical to do over buying a new system. There is a chance that a lens cleaner disc may remove any dirt that may have accumulated on the lens but it does not usually work due to the high cleanliness of the internals of the drive.
Sorry to be the bearer of bad news.
Thank you for using FixYa
