Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
How do i get rid of green snow on my tv - Digital Lifestyle FA1B32Z 32 in. LCD Television
    Top Expert:
  • Digital Life... Master
  • 76,237 Answers
Sounds like T'Con board fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Aug 08, 2014
I have a Maxent 42 inch plasma. The background has gone green and there is green snow in the picture. How do I get rid of this problem?
The green snow is usually a problem with the YSUS board. In the tv itself. You can attempt to have this tv repaired by a technician. Most likely it will end up costing you as much as a new tv, except you will have an old tv, with no warranty. A new tv will have all new parts. Newer and better technology and a new warranty.
Thanks,
Lee
Aug 11, 2009 | Maxent Televison & Video
My plasma tv has red snow in the backgrond
Usually the Z-sustain board takes care of that problem, however, I would have a svc center take care of that issue. Not to bad on $ to repair.
Feb 24, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. [email protected]
Dec 21, 2008 | JVC HD-61Z575 61" Rear Projection...
32 inch dell lcd3201c tv...
The cost to fix this is more than buying a new TV. get rid of it.
Nov 07, 2008 | Dell W3201C 32 in. LCD Television
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Green and red pixel snow
you can adjust the V-scan voltages the adjustor is on the Y-main board, locate the test point and adjust down around 15 volt
Jul 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Green and red snow
I had the same problem with Red/Green snow after 11mos of owning my Plasma. It was coevered under warranty thank goodness. The repair person had to replace all the inside circuit boards to fix.
Apr 02, 2008 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Green screen with pin stripes and TV shuts off after maybe 10 seconds!
Tom E...I have having the same problem with my Sony rear projection TV....it just started tonight, so I'm only now seeking a solution. Just curious if you've found anything out.
Sep 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
37 people viewed this question
Top Digital Lifestyle Televison & Video Experts
CoppellTVRepair.com
Marvin
Marvin
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
