Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Why doesn't my bottom arrow key work?
Why doesn't my bottom arrow key work on my apple mac book laptop?
Cedric Zumwalt
    Sergeant:
  • Apple Expert
  • 209 Answers
You may have something stuck under the key. You can try lifting the key a little or even taking it off and cleaning under it.
Posted on Aug 08, 2014
5 Related Answers
Anonymous
SOURCE: Mac book 2.1 gHz software
Yes, they will install it for a small fee of 39.99
Posted on Jul 21, 2008
Anonymous
  • 70 Answers
SOURCE: my mac book air doesn´t start, only the apple
probably the operating system is corrupted . Try to boot with installation media and repair the disk permission and restart the computer.If it boot after file permission repair then its fine or else you have to format it.
Posted on Apr 12, 2010
jgcalifornia
JG1977
  • 160 Answers
SOURCE: how to replace individual keys on key board of an
all models are different. Verify your model first. there are several "how to" videos on youtube, or other tutorials on how to do this. You need a steady hand, and to be careful.
Posted on Oct 05, 2010
DT65
  • 9 Answers
SOURCE: Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Posted on Apr 24, 2011
rahulgmehta1
Rahul Mehta
  • 59 Answers
SOURCE: My lexmarkprinterPrevailpro700 series will not
try to restart, check for any software update
Posted on Oct 31, 2011
How do you fix stuck keys on an apple computer
It is not a hardware problem and easily solved by technicians. If you don't have enough knowledge than try with any Mac Book Expert. Mac Book technician will guide you step by step for reliable solution. Follow https://discussions.apple.com/message/24231664#24231664#24231664 and Mac Help .
Jun 01, 2014 | Apple MacBook Air
Password won't work on Mac laptop
Hi There,
Since you don't say which password doesn't work, I'm going to assume you mean the password needed to logon to the computer itself...
If you have the OS (operating system) install disks that came with the laptop, or a Mac OS install disk, you can start up from the disk by inserting it into the optical drive when the Mac is on; then restart and hold down the "C" key immediately after hearing the chime-sound.
-You'll need to hold the "C" key down until you see a grey screen with the Apple logo in it and a spinning 'pinwheel' below the apple.
Once your Mac starts from the OS installer disk, you'll see the screen for doing a new installation of the operating system.
Click on the arrow at the bottom right corner of the window that comes up.
Then, look at the menu bar at top of the screen and click on the "Utilities" Menu, and choose "Reset Password".
This will open a new window that is pretty self-explanatory as to setting a new password for the various Users that have been created on your Mac.
Hope this helps & good luck!
Apr 18, 2014 | Apple Computers & Internet
Every time I search the internet, my mac save in my documents information and photos that I don't remember to open...What can I do?
When the "save" dialogue box opens look at it carefully. There is a bar towards the bottom that tells you where your download will be saved. Use those arrows and select "desktop", which will save the download to your desktop, where you can see it. You can then move it wherever you want.
Apr 03, 2014 | Apple Macbook Air 11.6" Laptop Mc505ll/a...
How do I eject a cd from my macbook pro
should be a small hole on the door its a manual release. insert a paper clip the drive will open
Oct 28, 2012 | Apple Mac Book Pro 13 In Laptop Computers
My Apple mac book wont start up. It just opens to a black screen - about 3 years old
When starting up the MacBook, hold down the option key. This gives you the choice of what disc to boot off of, if no drives show up, then your hard drive is corrupt and needs to be reinstalled. If the drive shows up, you can try booting off of it by selecting it and hitting the arrow. If this does not work, you can get your install disc out, comes with every Mac, and boot off the disk by holding the C key while starting up. After booting off the disk, you should be presented with the installer, pick you language but do not reinstall Mac OS X. Go to the menu bar and select tools, and then disk utility. In disk utility select your hard drive, and click repair disk. This should repair any errors disk utility found, now you can restart the computer and try again. If these do not work, you will likely have to reinstall your system.
May 05, 2011 | Apple Computers & Internet
Shift keY has become a letter Y, and the Y comes up in caps now, help!
did anything spill on your mac? Try blowing some spray air to clean in between the keys and keyboard. If that doesn't work, you can pop off the keys individually to see whats going on, but be very careful or take it to an apple store.
Jan 23, 2011 | Apple MacBook Mac Notebook
My mac book air doesn´t start, only the apple logo and the beachball spinning after restart
Mar 13, 2010 | Apple MacBook Air
My client has a Apple Mac Book and dont have connection
open system prefrences and select network, select the "bean" along the bottom "assist me" and then select diagnostics, follow the instructions
Mar 04, 2010 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Keyboard
Keyboards can range from $50 to $150+. Apple will probably charge under $75 for the install the new one. Check with a local apple store, or call 1-800-MY-Apple
Apr 24, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
Top Apple Computers & Internet Experts
Paul Carew
Lee Hodgson
Lee Hodgson
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
