HP Pavilion ze2000 Notebook Logo
Question about HP Pavilion ze2000 Notebook
If hard drive fails do u lose all data - HP Pavilion ze2000 Notebook
Larry Ng
    Top Expert:
  • HP Master
  • 11,307 Answers
Yes most times
but we move it to 2nd PC in USB dock and try.
using RECUVA (free) (saved some mine for a fact)
https://www.pcdied.com/HDD-SDD/recovery.html
imagine a newspaper
burned to ashes, no data there! then
now pretend only some pages or holes burn some, yes data but not all.
that is how HDD work, dead or 1/2 dead or fractions
even 1/2 of one fail gone.
if smart tests fail, on the drive run RECUVA on bad drive on 2nd good PC.
Posted on May 01, 2022
Imminent harddrive failure
Hard Disk about to fail This warning means the hard disk will fail sometime in the near future. You need to back up your data regularly before the hard disk fails or you will lose your data.
1720-smart hard drive detects imminent failure (failing attribute : 1)
This is a warning that your hard drive will fail in the near future. It is wise to backup your data frequiently so you won't lose your data when the hard drive fails.
The faults your hard drive is experiencing will cause the computer to slow down as it tries to read and write data to your hard drive.
There is nothing you can do to fix the hard drive except to replace it when it fails.
Hard drive errors
If your had drive is getting lost clusters when you run scan disk, it means the hard disk is nearly worn out Whilst scan disk will repair and locl out these bad sectors so data is not written to these areas, the number of bad sectors will increase and it is adiseable to back up your data frequently so you won't lose your data when the hard drive fails completely.
I recommend you replace this hard drive as soon as possible and install Windows on the new hard drive plus the computer's device drivers, your programs and data. You do not want the hard drive failing at an inconvient time.
1helpful
Hard Drive Crash - wants to re-install how to retrieve data to laptop computer
If the HDD has failed you can't retrieve the data off the failed drive. You can send the HDD into a data recovery company and they will read the disk in the drive and put the info on DVD and sent it to you, but that is the only way. The service is quite expensive. Just do a google search for failed hard drive data recovery.
My hard disk on nx9420 failed (i get the message 'critical error - imminent hard disk failure, save all your data'; but the computer will not boot (just says press 'control alt delete')....
This warningmeans the hard disk will fail sometime in the near future. You need to back upyour data regularly before the hard disk fails or you will lose your data.
When the hard disk fails, you need to replace with a new one and installWindows on the new hard drive to get your computer working again.
If you cannot boot up your computer then -
Remove the hard driveand connect it to an USB hard drive adapter and plug it into a workingcomputer's USB port. If this computer detects it as an external storage deviceand you can open the various folders and files then back up your data.
If not you are in trouble, there are companies that can recover data fromfaulty hard drives BUT it will cost you an arm and a leg for their services.
2helpful
I get a 1720 smart hard drive detects imminent failure (failing attribute : B8) on my HP probook 5220m, and on the desktop I get a warning icon on Intel (R) Matrix storage console (a hard drive is reported...
When the hard disk fails, you need to replace with a new one and installWindows on the new hard drive to get your laptop working again.
Microsoft Windows asking me to backup the files in drives because hard disk has encountered a problem. How to solve the problem without backing up of the files?
There is no way you can avoid this because if the hard drive fails you will lose your data.
Do you want to risk losing your data?
The problem could be some bad blocks on the hard disk and Scan Disk may fix this problem BUT there is a risk this process may wipe out some data files or may require re-formating the hard drive.
The hard drive may be corrected by re-formatting the hard drive, but this process will wipe your data off this hard disk.
SMART Failure Predicted on Primary Master QUANTUM FIREBALLP AS20.5 Arturo Sghedoni
This error message is a warning that the hard drive may fail in the near future. It is advisable to backup your data frequently so that when the hard drives fails you will not lose your data.
2helpful
Clicking sound when drive is idle all other times drive sounds normal drive is a samsungHD501LJ
This is an early sign that the hard drive may fail, I suggest you backup the data from this drive regularly so when it fails you won't lose your data.
Top HP Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
