Canon PIXMA MP620 All-In-One InkJet Printer Logo
A
Anonymous Posted on Aug 07, 2014
Can't print coupons from computer to canon printer
Hp printer will not print coupons
In addition to downloading and installing the coupon printer, please make sure that the coupon printer is enabled in your browser and that you are using a compatible browser. System requirements along with tips for printing can be found at http://help.coupons.com.
Thanks!
I cannot install coupon printer from coupons.com
You shouldn't need a coupon printer to print the coupons in the first place. The virus software is probably seeing something it doesn't like about the program. I would never recommend installing something like that especially when you can print things off the internet anyway. Stay away from installing downloaded things unless you really know they are safe.
I Have An HP D145 Printer That Won't Print Some Online Coupons Or Will Only Print Portions Of Them. Any Advice? Thank You
Most likely this is an issue with the way the website is displaying the coupon. Check to see if there is an option to print coupon. You might also try to create a PDF copy of the coupon and then printing the PDF document. Finally, one other thing you could try is to take a screen capture of the coupon, save as an image file or PDF and then print as an image or PDF. Hope this helps.
I have a iMac G5 with 10.4.1. I try to print coupons on my hp laserjet 1320 and they stay in the que. Word docs print fine but any time i try to print any kind of coupon from any site, it messes up the...
If you are printing PDF coupons, that is probably the case, you need to upgrade the memory on the printer if you want faster printing on those types of documents.
Can't print pictures from the internet.
You do not have  a photo printer, nor the software. You have a text printer.
28helpful
2answers
Will not Print online Coupos
Just fixed my Brother HL-5140. Hope this helps :) I have struggled for years and finally figured this out from the Brother website.
If you are unable to print coupons from the Internet the print processor
setting in the driver needs to be changed. To change the setting,
1. Open Printers and Faxes.
2. Right mouse click on the Brother printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Try printing the coupons again.
3helpful
The "keep printed documents" stays checked after i uncheck it!
Had the same thing happen. Go to properties, then advanced and check "print directly to printer". You'll be able to print your coupons. Make sure you go back to your previous settings when not printing coupons.
PRINTING COUPONS
whats the message you get?
should print sometimes i do a copy where i select all and paste it into word or notepad.
79helpful
8answers
Keep Printed Documents
If you have a Brother printer please change the following:
Start -> Control Panel -> Printers and Faxes -> Right click on your selected printer and select "properties"
Go to Advanced tab -> Print Processor
Change the settings from "BRMFC" print to "WinPrint" and set default to "raw" and Click Apply
Now go back to uncheck "Keep Printed Documents" and attempt to print the coupon.
I am a big fan of coupons.com, their tech support guy sent me these instructions. Good Luck!!
old marine
old marine
ZJ Limited
ZJ Limited
