Question about Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002
The odometer for 2000 s500 not working how can i fix it
All other gages work but the fuel gage and the odometer
kenllynch
    Sergeant:
  • 344 Answers
Replacement the speedometer the odometer is part of it.
Posted on Aug 13, 2014
How do I fix a fuel gage that reads on startup, then drops to empty.
If this vehicle is an early build, you may be able to get the instrument cluster to do a self-test? You press and hold the odometer reset button for 10 seconds, then release. The warning lamps may turn on and off, the gages may have calibrated movements. The odometer may display trouble codes.
I don't have good enough info to troubleshoot all possible issues.
May 09, 2016 | 2004 Chrysler Pacifica
How do I fix fuel gage on 1999 Blazer
The sending unit is bad. Some cars need the fuel pump replacd. May b easier to just record ur miles
Jun 22, 2015 | Ipcw Chevrolet Blazer Midsize 1998 1999...
What will cause your speed odometer gages go nuts and your brake lights to stop working?
sounds Like You HAve Ground Problem Clean the CABLE Goin to Your Battery And then Look On YouTube to See How They Do It Ok
Jun 23, 2012 | 2003 Ford Windstar
What makes the speed odometer work improperly?
there is a sender in the fule tank this may be faulty so its not sending the info to the tank gage find the whire from this sender on the fule tank and short it out to the car bodywork the tank should then read full up if the wireing is good, if there is still no reading its likley to be the gage not working, or a broken wire to the sender,,,if the sender is broken it canot be fixed so fit a new one but check how much fule is in the tank before you try to remove the old sender or it may spill out every were, if you fit a new selder only add a gall of fule and see if there is a reading on the gage before adding more so you find out when the tank is realy empty,, never trust the gage to be true
Mar 05, 2010 | 1998 Jeep Cherokee
Fuel gage is not working along with odometer checked for fuses did not find took apart dash found nothing there what should i check next. Tempature gage and oil pressure gage still work fuel gage is right...
when you pulled the top of the dash off did you check the cable connection to the insturment cluster. i had a similar problem where my gauges died individually including the spedo and tach. slapping the dash usually would cause the gauges to start working again, but that quit also and i had to tear the cluster out and check the conneciton. that fixed the problem.
Oct 26, 2009 | 1992 Saturn SL2
I cant see a petrol light anywhere on my dashboard on ford KA 2000
wont get one on till almost out of fuel just go by the fuel gage if that dosent work go by your trip odometer on your next fill up
Aug 22, 2009 | 2000 Ford Focus
94 ford probe,speedometor,oil gage,odometer not working
You need to pull the dash and check the guages look for any burning or melting. You may just need to replace the pannel in your dash, pretty easy work. If not start checking the wires and cables that come out of your faulty guages.
tepfy
Feb 22, 2009 | 1994 Ford Probe
Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002 Logo
133 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
