Question about Kyocera Office Equipment & Supplies
What is error code c/6 400 on koycera km2020 - Kyocera Office Equipment & Supplies
donovin mclain
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
Developer unit
MCY
1. Check that the developer waste lock has
been released and, if not, release the
lock (see page 1-2-15).
2. Check that the gears and spiral screw of
the developer unit are not damaged.
3. Confirm that the developer roller can
rotate.
4. If it won't rotate, replace the developer
unit (see page 1-5-57).
Developer motor
MCY
1. To check the motor operation, execute
DLP(MCY) by U030 (see page 1-3-34).
2. Check the drive gear can rotate or they
are not unusually loaded and, if
necessary, replace.
3. Confirm that the wiring connector is
firmly connected and, if necessary,
connect the connector all the way in.
Developer motor MCY and Motor
control PWB (YC7)
Motor control PWB (YC3) and Engine
PWB (YC9)
4. If the wiring is disconnected, shorted or
grounded, replace the wiring.
5. Replace the Developer motor MCY.
Motor control PWB Replace the Motor control PWB
Engine PWB. 1. Check the engine software and upgrade
to the latest, if necessary.
2. Replace the engine PWB (see page 1-5-
80).
Posted on Nov 25, 2014
1 Related Answer
saxmansaxman
walter jansz
  • 177 Answers
SOURCE: i need heip for koycera km1620 ofter the copy
This issue is a problem with the scanner cable check the scanner cable for a break or tear make sure you unplug the machine from wall outlet and power of machine
you will need to replace this cable problem will be fixed
Posted on Feb 12, 2011
Error C-6 need code
replace fuser unit then 1087 1087 163 start
Nov 25, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
ALL KYOCERA MITA 1620 ERROR CODES
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Kyocera-Mita&model=KM1620
May 21, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
C-6 400 what does it mean on kyocera KM-2020 photocopier machine
Hi my Kyocera KM2020 is showing an error code C-6 400, what does it mean and how do I fix it? Thanks
Jan 29, 2013 | Copystar CS-1650 All-In-One Laser Printer
I need heip for koycera km1620 ofter the copy machine send error code A-3200 pl solve the problem
Feb 11, 2011 | Kyocera Copystar CS-1620 Black and White...
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
115 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
