HP LaserJet 1320 Printer Logo
A
Anonymous Posted on Aug 07, 2014
Printing on both sides
Upgraded to Windows 8 pro no longer able yo print on both sides
W.L.
Level 3:
  • Master 2,511 Answers
  • Posted on Aug 07, 2014
W.L.
Master
Level 3:
Answers
2511
Questions
Helped
523663
Points
8345
Make sure the Automatic Duplexing option is enabled:
Enter Control Panel then Devices and Printers.
Right click the printer icon, then Printer Properties.
Click the Device Settings tab.
Set the Automatic Two-Sided Duplex Accessory as installed and click OK to save.
Now Automatic Duplexing should become available.
My LaserJet 1320 will no longer do duplex printing with Windows 8
3 Related Answers
Anonymous
  • 54 Answers
  • Posted on Apr 15, 2009
SOURCE: Double sided printing
To fix this issue, select on the start button on the bottom left of your screen then click on Control Panel. In Control Panel click on printers. Left click on the OfficeJet G55 printer once then right click on it and select Properties. Click on the Printing Preferences button then on that window that pops-up select on the Finishing tab. If you have the correct drivers installed, you will find an option there (a check box) to enable to print to both sides. Check that if you have it.
Hope this solves your problem. Let us know if it don't.
Thanks.
Anonymous
  • 7 Answers
  • Posted on Oct 09, 2009
SOURCE: How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Anonymous
  • 1049 Answers
  • Posted on Mar 08, 2010
SOURCE: Printing double sided documents. With my old
Go under advanced settings in the printer properties and specify that the printer has a duplex option.
Is there and upgrade for print perfect platinum that will work with windows 8.1
Do a web search for the company that makes it. That should find any updates.
I'm not an expert on windows 8 but I'm certain there might be an option in Windows 8 to let the software run under Windows 7. For more information visit the Microsoft website.
2answers
Ms publisher printing
Using the most current print drivers. Try this site
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
What's your problem?Hi! I am having problem with my HP Officejet Pro K550. I used to have Window XP but now I have a new Window 7. My problem is that, when I first started with Window 7, double
Maybe the problem is the OS with which you work, then evaluates the importance oftwo-sided printing.
If the problem persists with your Windows XP might be mechanical failure, if so, yourprinter problem is that your ADU (automatic duplexer unit) no longer works. You canget another printer or changing ADU.
good luck
2answers
Reinstalling 2002 pro
Sorry to tell you that you will need to upgrade. Quickbooks is only compatable with Vista in 2008 and up. Quckbooks is not doing anything to resolve older issues.
k24674
Grand Canyon Tech
Grand Canyon Tech
