Question about Taylor Health & Beauty
SOURCE: owners manual for WW 47 bathroom scale
This link allows you to request user manuals...
I hope this helps.
http://www.conair-store.com/cc_contactus.asp
Posted on Jan 07, 2009
SOURCE: Error message ErrL
My scale had the same problem. I replaced the battery, but still got the same message. My wife noticed that one of the feet on the bottom of the scale was loose. The feet are twisted on to the scale and held by two small flanges. When I gently pulled the loose foot away I noticed that a small black wire had broke. I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together. I then hide the wires back in a recessed area on the foot and placed it back on the scale. Worked just like the day I got it. Hope this helps!
Posted on Feb 20, 2009
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Posted on Mar 16, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: Conair #WW78 scale doesn't reweigh
;i have a problem with the conair ww78. It does not reweigh. It shows the same weight each and every day. What is the problem and how can it be fixed?
Posted on Mar 22, 2010
Nov 13, 2017 | Weight Watchers Health & Beauty
Nov 15, 2012 | Taylor Biggest Loser 7206 Electronic Cal...
Feb 19, 2012 | Conair Weight Watchers® WW78 by Glass...
Jul 04, 2011 | Vacuums
Feb 28, 2011 | Conair Weight Watchers WW-87 Body Fat...
Jan 07, 2011 | Taylor 5568 Fat Scale Stainless Steel ()
Sep 15, 2010 | Conair WW81 Weight Watchers Body...
Apr 24, 2009 | Conair WW60 Weightwatchers Scale
Mar 16, 2009 | Taylor 7532 Ultra Thin Glass Digital Scale
Mar 18, 2008 | Computers & Internet
44 people viewed this question
